My "audiophile" LM3886  approach
Old 20th October 2005, 12:16 PM   #1151
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
Default Re: It's alive!!
Originally posted by rabstg
I listened to Lyle Lovett�s "I love Everybody" CD and sat in amazement.
And I can say that after 2 cd's! The tone, pitch and pace were dead on. It was smooth and DETAILED!
Thus far I am absolutely amazed at what is coming out of this inexpensive amp!
Troy,
I know the feeling! I had been biased for a long time that nothing could approach the quality of big dollar big current (but not necessarily big output lol!) Class A amps. Well this amp clearly blows that myth away. After months of critical listening I would choose "My Ref" over my KSA-50 or my Aleph 30SE.
You did an awesome build. Thanks for being a beta tester. It is guys like you who make this fun for me, and thats the whole point really.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 20th October 2005, 02:51 PM   #1152
troystg is offline troystg  United States
troystg's Avatar
Default Re: Re: It's alive!!
Originally posted by Russ White
Troy,
You did an awesome build. Thanks for being a beta tester.Cheers!
Russ
I will be cleaning up the wiring and layout shortly to make it much "prettier" inside.
Please hurry on the source selector and Kookaburra so I can put those in!
EDIT:
By the way, I can solder pretty well, but for fun and an even better job I had Repute assemble the boards... He did a fabulous job, and I was very happy with the outcome.
If anyone wants a kit built and can't do the soldering required, they can Email Repute and maybe work something out... I am NOT advocating Repute for anything, he is just a long time friend that did PCB rework in a prior lifetime. I would just hate to see someone miss out on this GREAT amp because they can't solder.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 20th October 2005, 03:40 PM   #1153
float is offline float  England
Well, I can't resist any more.....
This little hussy has been tempting me for a while; I thought I'd probably try a Ucd400 instead but with funds being shorter than ambitions .....
Question to the Pear chaps- can I still get in on the first delivery run of the kit (oct 24th?)
Weeks to make my mind up and now I WANT IT NOW!!
I w isH i cuold typpe bettr
Old 20th October 2005, 04:09 PM   #1154
Russ White's Avatar
Absolutely, we have plenty of PCBs which are in stock right now, and can ship now, and kits which should ship by Monday.
Enjoy!
Cheers!
Russ
Old 20th October 2005, 04:36 PM   #1155
Hi Russ, payment made and I'm rubbing my hands in anticipation
I'm hoping it will stamp all over my current Audiolab.
I'll let you know how I get on. Watch out for smoke on your east horizon
Old 20th October 2005, 04:44 PM   #1156
Russ White's Avatar
Hah! I truly hope no smoke appears.
Have fun!
Cheers!
Russ
Old 20th October 2005, 08:32 PM   #1157
motzu' is offline motzu'  Romania
motzu''s Avatar
Send a message via Yahoo to motzu'
Finished my first Gainclone Rev_A
Pictures ( warning, each one, full size - about 800k !!!) at :
ftp://ftp.dallnet.ro/public/hi-fi&stuff/Gainclone/
DIY case, black painted - one 400 VA @ 2x22V toroidal transformer
2x15000 microFarads on each rail - I'm not sure if they're really Rubycon
The list of components sticked to Mauro recomandations.
PCB's made at scale after Mauro's PDF at a local manufacturer.
Speakers are 4 ohms ones. T+A .
First impressions : detailed, powerfull, with a LOT of bass . I mean a LOT !
Maybe that's why a have the impression that, somewhow, highs are little bit less present than with my Yamaha , for instance.
One strange issue - one of the chips is getting a litlle bit warmer than the other one .Sensible warm ! Also the chips are warm if the amp is left alone with the power on but with no input at all.
Otherwise - is extremely quiet . No hum at all, even at maximum.
Mr.Penasa , could you be so kind to advise if and how is possible to connect the actual module in paralell mode. Would they be any implications regarding your concept ?
Regarding the high frequencies .Have I done something wrong or is just my ear ?
Could it be a high frequency oscilattion heating my chips differentelly and also heating the chips even with no signal ? Should I move to Rev_C ?
Thanks for your nice threads, everybody.
Best Regards
Old 20th October 2005, 09:17 PM   #1158
carlosfm is offline carlosfm  Portugal
Banned
Warmer than a Yamaha, impressive.
May I suggest you to try snubberizing those big caps?
You'll get tighter bass, cleaner and more detailed midband and treble.
Sorry guys, I couldn't resist.
Old 20th October 2005, 09:39 PM   #1159
troystg's Avatar
Carlos-
I will try two 2 tweaks to my amp:
1. Op-amp zener change to 18volts from 12
2. your snubbers
The zener is a no brainer, but may I ask you what values to try for the snubber?
I have the stock rev c kit using dedicated 25-0-25 volt transformers.
I can't wait to go home and set up the amp down stairs to listen to over the weekend as I very seldom get to listen upstairs in the tv room.
Troy
Old 20th October 2005, 10:00 PM   #1160
Banned
...may I ask you what values to try for the snubber?
0.1R + 3.3nF
My "audiophile" LM3886  approachHide this!Advertise here!
Copyright ©1999-2017 diyAudio
