Old 31st March 2005, 02:17 AM   #1
Bose(o) is offline Bose(o)  Canada
Default Op amp trouble shooting
Alright, I'm on my last threads for troubleshooting my attempt at the CMoy amplifier. I decided to build the amplifier first on my breadboard to no avail.
I got little sound, if I got any sound it was clicking and popping, removing the DC blocking parts (cap and resistor) removed this problem. However, I still didn't get sound....whisper quiet sound is good if you want to attenuate, but the idea behind this amplifier was to amplify.
I am still at a loss and am VERY frustrated, I have every piece of electrical test equipment at my very hands. My split power supply is PERFECT, only problem is the op-amp. Even using the op-amp as a Voltage Follower doesn't fix anything.
I've tried using different breadboards yet nothing still. I've bought new batteries 3 times already and still nothing.
Right now, I officially hate op amps.
I can get audio on the -'ve voltage rail, and I'm not even sure how, but there's more audio there than from the output.
TIA
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 31st March 2005, 02:50 AM   #2
Oh yes, I'm using the Burr Brown OPA134PA.
ERTW 4 life!
Old 31st March 2005, 03:07 AM   #3
I_Forgot's Avatar
schematic?
I_F
Old 31st March 2005, 03:22 AM   #4
Russ White's Avatar
Send a message via Yahoo to Russ White
Are you using one or two OPA134PA?
Old 31st March 2005, 03:52 AM   #5
I can't get a schematic thus far, because the website is down BUT I have hooked up the amplifier via unity-gain and she no work.
ERTW 4 life!
Old 31st March 2005, 04:13 AM   #6
"Are you using one or two OPA134PA?"
...still a quite pertinent question...
Old 31st March 2005, 05:56 AM   #7
Are you sure the connections are correct? This bit me when I started out with opamps - I'd wired the circuit board perfectly well if the opamp would have been plugged in upside down. Ooops.
Francois.
Old 31st March 2005, 06:50 AM   #8
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Op amp trouble shooting
A CMOY is very easy to get working but since you are a newbeginner it's essential to have a schematic at least.
Headwize will be up 1st April. If you meanwhile can draw the schematic or at least take a picture we maybe can help you.
/Per-Anders (my first name) or P-A as my friends call me
Old 1st April 2005, 06:32 PM   #9
That's the thing, I'm only n00b at op-amps, it's sad really.
Anyway, I'm using one OPA134 right now, amplifying just one channel (left or right, no diff.)
ERTW 4 life!
Old 1st April 2005, 06:33 PM   #10
Power Supply
ERTW 4 life!
Need help in trouble-shooting my AES Sixpacs amp andy2 Tubes / Valves 2 12th January 2007 10:52 AM
trouble shooting my DD receiver kslim Solid State 0 1st December 2004 01:21 AM
Help trouble shooting Christof Tubes / Valves 11 1st September 2004 03:27 AM
need some trouble shooting help Jean Solid State 41 7th October 2002 05:53 AM
Trouble shooting help NerdMike Solid State 2 29th September 2002 01:34 AM
Page generated in 0.12357 seconds (71.43% PHP - 28.57% MySQL) with 11 queries
