| Chip Amps Amplifiers based on integrated circuits |
hello,
i couldn't find a thread regarding this, but would digital volume attenuation be better than analog (like a stepped attenuator) volume control? if i went about building a DAC would it be best to have the volume control at the DAC level? thanks, fred |
#2 |
I just ran into this today for posting on another forum, so I might as well re-paste it here:
http://pdfserv.maxim-ic.com/en/an/AN1828.pdf No sense using ADCs/DACs. There are already devices that do the trick for you. I can't see this approach being any worse than using a stepped attenuator, unless you go all out on the resistors that you choose to use for the attenuator. Even then, I'm not sure the difference is worth the money. :P If I ever get a chance, I will likely use the parts listed in the app note above and give it a go. Cheers, Chris
http://www.SuperMegaUltraGroovy.com Finally! Acoustic Measurement software for Mac OS X -- http://www.fuzzmeasure.com |
#3 |
hello,
what i'm asking is the digital attenuation of the signal pre-dac stage. so if a sample is at 175, i attenuate it to 100 etc., then i but that 100 value into the dac, hence an attenuated signal without aditional circuitry. thanks, fred |
#4 |
In this case, it is most certainly better to attenuate in the digital domain if you can. I'm not too sure how to go about this, though.
Perhaps the DAC can do this internally? Chris
#5 | |
Banned
It's not the way to go. |
#6 |
You lose S/N ratio no matter what you do, digital or analog. There are pros and cons to both methods, although the only really decent digital attenuation will be DSP-based.
I think that as long as we are speaking of 20-30dB max attenuation, a good digital domain attenuator will be just as good as an analog one, especially if it means eliminating buffers etc from the signal path. This is provided we are attenuating 24 bit data. YMMV. |
#7 |
hello,
thanks for the reponses: |
#8 | |
I always opt to do all other types of processing in the digital domain if I can, when the signal is starting off in the digital domain. Personally, I just know how to do things in the digital domain properly, so I always take that route if I can. ![]() Chris
#9 |
I have similar question
. In my tube preamp (AR LS8) i have two chips (one for each channel) as electronic attenuator that are microprocessor controled, so I am wondering is this better approach then the classic high quality analogue pots like Alps "Black beauty" or mechanic step atenuattor.
| CDP analog output bypass versus upgrades | trans | Digital Source | 4 | 24th November 2008 04:19 AM |
| Digital attenuation for i2s | fcserei | Digital Source | 15 | 26th September 2005 05:26 AM |
| Digital/analog volume control experience | janneman | Solid State | 26 | 10th March 2005 09:08 PM |
| analog attenuation of AD1853: page 10 in datasheet | EJ | Digital Source | 1 | 7th August 2003 12:09 PM |
| remote volume control digital? analog? | happyben3 | Solid State | 8 | 5th August 2002 01:49 PM |
| Page generated in 0.09160 seconds (86.03% PHP - 13.97% MySQL) with 10 queries |
