| Chip Amps Amplifiers based on integrated circuits |
Has anyone tried the basic bridge/parallel circuit for LM3886 as shown in Figure 17 at http://www.national.com/an/AN/AN-1192.pdf (page 15). I need at least 175W RMS of clean power for a sub. I intend to use 4 ICs or maybe 6 for a 4 ohm 12" driver. What should be the supply voltage? Thanks in advance, Goldy
Audio enthusiast/hobbyist |
#2 |
DIY !
Ars longa, vita brevis |
#3 | |
#4 |
I intend to use only a pot at non inverting input to reduce the offset. But as I read in other threads, it will not reduce it beyond a point. How much of offset voltage is safe if I use 0.22 ohm at the output of each LM3886? The number of chips per side of the speaker is 3 (total of 6). The supply is 28-0-28. Thanks in advance, Goldy
#5 |
I built mine without servo, and just to share what i learned:
1. Resistor matching is important. Be friendly with the store owner and they will let you spend a day in the store selecting your resistors. 2. Chips has 'internal offset', so build a few to select the ones with the least offset. My sub amp has dc offset of about 200mV (I didnt observe rule #2) But for a 200-watter, I dont really care. There is more than enough power to dispense and my sub can take that. |
#6 |
I agree with skyraider"s two points.
I used trim pot on the non inverted inputs. I built 20 indepentent modules. I picked 16 modules with the closest dc offset,then I broke that group into four group all with dc matched as close as possible. I ended up with four nearly matched parallel groups. I used two parallel groups(8 modules in total) with a drv134,to make two monoblocks. The dc offset in .0003 on one and .0001 on the other. One thing I would add make sure all connection are proper and solid or you will get hiss. |
| To use DC servo or not? | jaycee | Solid State | 40 | 17th September 2007 02:04 PM |
| Servo add-on PCB | Nicks | Chip Amps | 3 | 21st February 2006 05:36 AM |
| To servo or not to Servo.. | ReSiStAnCe | Chip Amps | 10 | 7th February 2004 01:06 AM |
| DC servo | Bensen | Solid State | 0 | 23rd May 2003 11:34 AM |
| Page generated in 0.09173 seconds (75.74% PHP - 24.26% MySQL) with 10 queries |
