There is a PCB layout in the datasheet - not like Gerber files you could copy directly, but it should help.
http://cache.national.com/ds/LM/LM1875.pdf
Hi!!!I actually want to build non inverted gainclone, and i still confuse about the power supply. What are the value of capasitor in the +25output and -25 output???Do i need to use 10000uF capasitor???Is it possible to get + 25v and - 25v from 18 0 18 transformator???What about the ampere of the transformator???3A??
enquiry about the cap
hi,
in the gainclone amplifier board done up by sijosae, what type of capacitor is the Orage 1uF one. (i mean epoxy or resin etc?) i have been unable to locate this type of capacitor maby because i dont know what to call it.
Thanks in advance for the help.
hi,
- Chip Amps
- Need LM1875 PCB layout !!
