| Chip Amps Amplifiers based on integrated circuits |
Happy Easter! I'm going to try a PEC 1M linear pot T recommended in my BrianGT 3875 project. I recall T writing that the appropriate law faking resistor value is 33K-47K. Is there an advantage to either end of the spectrum? I believe that 47K should result in a better taper. But if I use 33K will I be able to remove the 22K resistor at the input as P.D. does with a 25K pot? Sorry if these questions have been answered before, but I can't find them. I know the best way is to try different configurations, but I want to get as close as I can to begin with.
thanks, Paul |
#2 |
Mark Kravchenko --- www.kravchenko-audio.com
THe best way is to try it and plot the values on graph paper. To get some measure of repeatablity you might want to mark out points on the dial and plot them on some graph paper. You will be happy with either. But the higher resistance will give you what you want.
Mark
Mark |
#3 |
Did it Himself
To save you all that do a search on 'law faking' for posts in the last 6 months and you will find a spreadsheet.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa |
#5 |
Thanks homer09! That was exactly what I needed. For some reason I was having a hard time finding that post in my searches. I needed to search for "linear" instead of "law faking". Did you end up going that route, and if so, what did you use?
#6 |
Did it Himself
That's the spreadsheet I was on about. homer09 wrote it so I'm sure it was easy for him to find
Sorry I wasn't too good with my search instructions, I couldn't quite remember the exact thread it was in.
#7 | |
Glad to help I havent actually tried law faking for real yet, my amp building project is a very slow and ongoing task... i am in university full-time, so this can't be a priority. But, I am planning to implement a fake-law in the amp i will be starting/finishing within a month and a bit. I chose a 250K linear PEC pot, and im leaving the 22K shunt resistor in place on the BrianGT LM3875 board. I think this should give a nice volume curve.If you jump ahead with your 1Meg pot, i would love to hear your results! post them on the thread with the spreadsheet.
| law faking.... with an R2R | adamus | Parts | 1 | 19th March 2010 11:19 AM |
| Law faking issue | oshifis | Parts | 2 | 6th April 2008 08:57 PM |
| Un-Faking a log pot | pixpop | Parts | 2 | 31st May 2006 03:57 PM |
| Simple law-faking advice... | darkmoebius | Chip Amps | 3 | 23rd December 2004 03:26 AM |
| Magnetic Law Faking Volume Control | mrfeedback | Everything Else | 0 | 3rd May 2002 04:21 PM |
