How to use LED with +- 25v tranny?
Old 27th March 2005, 03:10 AM   #1
ransom peek is offline ransom peek  United States
Default How to use LED with +- 25v tranny?
Building brian gt lm3875 rev 3 stereo gainclone, with Avel 330va +-25volt tranny, expecting +-35vdc after power supply board rectification and filtering.
Have very small enclosure and want to use this power switch/LED "12V LED" combo, but not sure if I can drive this LED.
http://www.mouser.com/catalog/specsh...SH-R13-523.pdf
This is the Mouser part, and it only says pushbutton switch, 3A 125Vac, 12V LED illumination. 3 amp should be just enough, but how to drive this LED - is it possible?
Old 27th March 2005, 04:03 AM   #2
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
SivanandBalan
Old 27th March 2005, 04:19 AM   #3
jcayer is offline jcayer  Canada
6K8 1 Watts (at least )
Old 27th March 2005, 07:46 AM   #4
sivan_and's Avatar
SivanandBalan
Old 27th March 2005, 01:34 PM   #5
megajocke is offline megajocke  Sweden
megajocke's Avatar
LEDs don't like reverse voltages over 5 volts.. Put in an antiparallel diode or a diode in series...
Old 27th March 2005, 01:44 PM   #6
sivan_and's Avatar
megajocke wrote:
True....but therez no reverse voltage here....LED is connected to DC...
SivanandBalan
Old 27th March 2005, 07:17 PM   #7
Default Still puzzling LED circuit - not always so simple!
Thanks so much for helping. Still a puzzler though...
Is that a 6K ohm resistor? I dont understand why 1 watt is required, LEDs draw around 20 ma... Please clarify...
Since the switch includes the "12 volt LED", wouldnt that mean there is already a series resistor included in the device, chosen so that the led fires correctly with 12 vdc?
If so, wouldnt then choose a resistor that, together with the inclued resistor (series) would total 6k, or better yet try increasingly lower values until something around 20 ma is drawn...
Seems that datasheet is not detailed enough...
Old 27th March 2005, 07:27 PM   #8
GregGC is offline GregGC  Canada
Default Re: Still puzzling LED circuit - not always so simple!
According to the picture above: 35+35=70V 70V/6.8k=10mA (LED current)
10mA x 70V = 700mW (the power dissipated in the resistor)
Hope it makes sense
Greg
Old 27th March 2005, 07:36 PM   #9
Default Getting Closer but not there yet!
Thank Greggc (is that gc for gainclone?)! Now it's clear. It just didn't seem intuitive that a 1 watt resistor would be needed for an LED.
But, I still think there is likely to be a resistor inside the switch/led assembly that will be in series with the added resistor. So, I'll check it. If there is a resistor there, I think it wont work, because the spec sheet says 12 volt led, so at +- 35 vdc = 70 vdc, the current rating of the internal resistor will be exceeded. Now, an added series resistor will drop some of the voltage.
So I need to figure out the math on this one...
Old 27th March 2005, 07:50 PM   #10
indoubt is offline indoubt  Netherlands
indoubt's Avatar
Another very simple, efficient method is to take a thin isolated wire and make 5 windings on your transformator. To be shure just measure the voltage that this 5 windings will supply. Works like a charm and does not have any adverse effects on any of the circuits (if it would at all, in some cases it is mentioned that leds coud have an audible effect if you place them on the supply rails, I have never been able to hear it though)
better be indoubt untill you're sure
How to use LED with +- 25v tranny?Hide this!Advertise here!
Now I know what this Tranny can do Tarzan Tubes / Valves 3 8th January 2009 08:37 AM
Another Tranny Question bcrescen Chip Amps 7 26th September 2006 05:42 AM
Tranny Qs? henkel Parts 4 12th September 2006 04:58 PM
What can I do with this tranny? ThSpeakerDude88 Chip Amps 15 28th July 2005 04:29 AM
what should I do with this tranny??? mylesmf Tubes / Valves 6 9th June 2005 12:42 AM
