| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I built about 2 months ago a powered subwoofer using 2 OPA541's bridged, now it had some problems and i fixed them today, but still have the humm... I have checked for any ground loops but didnt find any, but then while the amp was on, and playing music I touched the heat sink and the humm dissapeard! but, but... the OPA's share the same heatsink and are not isolated, because the tab is the -Vs, but when I check to see if there is any kind of connection between the tab and the -Vs pin (on the data sheet it sais there is), there is no connection. So what do I do?? do I ground the heatsink? well I cant because the chips are not isolated and the -Vs should be going through the tabs, so again, what do I do? Thanks, Kinser |
#2 |
I think I would isolate the chips.
#3 |
Russ White,
Thanx, I will do that, but i would like to know why is there a hum, because both tabs are V- Thanks, Kinser |
#4 |
I am not sure, but I have seen the same sort of behaviour out of LM4780s and that solved my problem. Wish I could tell you why.
#5 |
Hey Russ White,
Thanx anyway.. I'll go tmrw to get some mica or somthing... Thanks, Kinser |
| Opa541 - Bpa-200 | kinser | Chip Amps | 5 | 11th September 2005 08:43 PM |
| help me with OPA541 | Oxujens | Chip Amps | 9 | 7th April 2005 07:33 PM |
| opa541 | sss | Chip Amps | 3 | 6th August 2004 10:27 AM |
| OPA541 Bridged | audioPT | Solid State | 4 | 17th November 2003 06:21 PM |
| opa541 | pundip | Solid State | 5 | 2nd March 2003 06:08 PM |
| Page generated in 0.07875 seconds (67.75% PHP - 32.25% MySQL) with 10 queries |
