Old 26th March 2005, 12:29 PM   #1
Russ White's Avatar
Send a message via Yahoo to Russ White
Default BrianGTs LM3886 input resistor R1
If you are using a cap on input and Ci can you simply omit and jumper the pads for R1 as there should be no DC offset?
Thanks.
Old 26th March 2005, 01:29 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
This resistor is there to provide certain isolation between amp input and outside world. In most cases you don't really need it, and presently, I'm not using such. Even replacing Caddock or Vishay with a short, brings improvement in low level detail and neutrality.
Sometimes using that resistor may equalize some brightness that other GC components may introduce, and in such cases Vishay S102 works quite well as it adds certain smoothness and more body. Caddock, OTOH, seems to be more neutral, preserving same signature of trebles, but it may be somewhat bright.
The value of that resistor is not critical; National suggests 1k, I've been using 220R ( I was probably influenced by Alephs schematics ). But anything between 220R and 1K should be fine. Higher resistor value brings slightly stronger signature, but this is very slight effect.
So, you can remove that resistor, and the circuit should be working fine without it (in most cases at least). You may even notice an improvement.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th March 2005, 01:29 PM   #3
Russ White's Avatar
Default Tried it.
OK, I got impatient and just tried it and hoped for no smoke.
It worked fine, and DC offset is still 0. Sounds great.
Old 26th March 2005, 01:31 PM   #4
Russ White's Avatar
Thumbs up Excellent!
Thanks for the kind reply Peter. That was exactly the kind of info I was looking for!
Old 26th March 2005, 02:31 PM   #5
Russ White's Avatar
would bypassing signal ground in a similar manner also be helpful in some cases?
Old 26th March 2005, 02:35 PM   #6
What do you mean exactly?
www.audiosector.com
Old 26th March 2005, 04:31 PM   #7
Russ White's Avatar
I mean putting a similar value resistor as R1(if you use one) in series with SG prior to attaching SG to the PCB. I think I used the term "bypass" incorrectly. Maybe I should say isolate.
Old 26th March 2005, 04:46 PM   #8
SG has to be connected directly, but you can try separating SG from OG by 3 ohm, or similar, resistor. This would require cutting one trace though.
www.audiosector.com
Old 26th March 2005, 05:11 PM   #9
Russ White's Avatar
The reason I asked is because on a preamp I am working on right now I have a small problem with humm and hiss when connected to my GC. Nearly none however when connected to headphones.
The preamp is a opa2228 with 2 buf634s one for each channel.
Well, I put 1K resistors on the outputs of the BUF635s and a 1.75K resistor in sereies with the power ground running from the power supply to my star ground. The helped a lot for the humm, but I am not sure if I am harming the circuit.
The power supply is fed by a 30V wall wort and vortual ground is created with a simple volateg divider with 4.7K resistors.
Could I use even higher values for my isolation resistors, as I still have some humm?
Old 26th March 2005, 05:22 PM   #10
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I'm Also starting to have Problems with my gain clone's and passive pre-amp When connecting another amp ithe other amps hum useing a active xover it hums too. Disconnecting the gain clone amp and using any other type of amp it works just fine and no hums. What could it be ?
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Three-resistor LM3886 chipamp Mick_F Chip Amps 20 14th August 2006 02:59 PM
[LM3886] Best resistor value for mute ? XELB Chip Amps 50 16th November 2005 09:57 PM
My Lm3886 based on BrianGTs Boards filholder Chip Amps 30 31st March 2005 07:20 PM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 04:59 AM
Page generated in 0.10507 seconds (78.97% PHP - 21.03% MySQL) with 10 queries
