Struggling with my buffered GC preamp
Old 26th March 2005, 12:11 AM   #1
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
Default Struggling with my buffered GC preamp
I have built a second preamp from my Lm3886 GC and here is how it is set up.
1) The schematic is pretty much the same as the headphone amp application note on TIs web site for the BUF634.
2) I am using the OPA2228 as the opamp.
3) I have the gain set at 11 with 4.7K and 470R resistors.
4) Input inpedance is 100K.
5) I have a 100K stereo volume control pot from rat shack.
6) I have 220 ohm resister on the BUF634 bandwidth setting pin to V-.
Here is the problem. The thing sounds excellent at both ends of the pot within 1/4 of both ends of the pot, but anywhere near the middle I get all kinds of noise that is the worst at the middle of the pot.
Is my pot to high a value? Should I get a 10K or something?
as I noted my input inpedance is 100K. Tried with 470K and it was as bad maybe worse.
Any ideas. I have searched the forum for two hours and I am still stumped.
Old 26th March 2005, 12:42 AM   #2
Russ White's Avatar
Default Update
Ok, just connected the preamp to my headphones, and the problem does not exists when driving the headphones. It sounds great actually.
This made me think it might not like the cables to my amp or the input impedance of my amp, so I added a 120R resistor in series with the output of each buffer. Still sounds good on the headphone, but the power amp is still getting terrible problems at around mid pot. Both ends still fine.
Old 26th March 2005, 01:10 AM   #3
Russ White's Avatar
Default Update #2
OK, for kicks I tried "tuning" the noise, and got a close by AM radio station, but once again only when the preamp is connected to the GC (BrinGTs LM3886). When connected to headphone only the slightest hint of hiss right at mid pot, but otherwise silent.
Old 26th March 2005, 08:12 AM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Yes, try a 10K pot!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Struggling with my buffered GC preampHide this!Advertise here!
buffered preamp power supply starbase218 Solid State 12 2nd December 2007 02:29 PM
Nuuk Buffered Passive Preamp Issue filholder Chip Amps 51 22nd November 2005 09:00 PM
struggling with enclosure dimensions hotchin2k Subwoofers 10 26th May 2005 05:07 PM
oscillation in passive buffered preamp Flemming J P Solid State 13 22nd December 2003 04:42 PM
Buffered Passive Preamp Freddie Solid State 22 30th June 2003 09:05 PM
Copyright ©1999-2017 diyAudio
