| Chip Amps Amplifiers based on integrated circuits |
Finished my integrated LM3886 GC at last. It's a low cost, fully integrated 20W+20W with preamp, buffer and PSU onboard.
It's designed to be low-cost as it's intended for my computer gaming speakers. Yet it sounds really good and lab measurements show max power at 30W RMS per channel and 0.0V DC offset. With the preamp section bypassed, it's totally noise/hiss free at the output. I put everything on the PCB (even transformer & heatsink) as I wanted to drop it into a small, low profile case. If anyone's interested, I have schematics, PCB layout and lab measurement data that I can post. There's also a few bare PCB's left from the proto build. Thanks for looking. PS: Sorry for the low-res pic. Had to take in a hurry. |
#2 |
Here's an overview of the PCB layout. Ground plane is on the bottom layer and is not shown.
#3 |
Lots of parts. Looks good.
What's the long DIP IC in the upper right corner? |
#4 |
Why not try to manufacture more and sell them???Lokks so good!
#5 |
Very nice. Should make for a very compact little amp. Did you have a chassis in mind when you started? Also, what tranny did you use?
#6 |
Electrically good!!
Mechanically..POOR design.. Whats the point in having the Tranny on the PCB? hope it will not break the PCB...Single module look? what about the PCB space wasted?
SivanandBalan |
#7 |
Very nice design !
#8 | |
(I'm asking because "tranny" makes me think of a transistor which usually isn't misplaced on a PCB.) |
#9 |
O_o the transformer question.
It's only a 80VA part (more than ample for 20W + 20W output) so it's weight it's not a problem. The main reason I wanted the transformer on the PCB is that this design will also be built by some students that I am mentoring. Some of them have a tendency to run the amp as it is and I didn't want any AC wires dangling for safety reasons. I left my documentation at my work PC so I'll post schematics and such on Monday if anyone's interested. Thought it'll make a nice first time project for newbies. |
#10 |
the pcb looks good , did u make it yourself?
if you are not living on the edge you are taking too much space
| Fully digital amplifier. | oon_the_kid | Class D | 34 | 12th November 2008 08:48 PM |
| New/Old Integrated LM3886 PCB | Arius | Chip Amps | 12 | 10th October 2008 02:49 PM |
| My LM3886 Integrated Amp | panson_hk | Chip Amps | 12 | 11th September 2007 04:43 AM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| TI Introduces Industry's First Fully Integrated, Single-Chip 100-Watt Digital Audio A | mikejz84 | Chip Amps | 14 | 9th December 2003 07:37 AM |
| Page generated in 0.12584 seconds (74.01% PHP - 25.99% MySQL) with 11 queries |
