| Chip Amps Amplifiers based on integrated circuits |
Am building Brian GT lm3875 rev 3 in a small wood enclosure. 330 VA Avel toroid, and a substancial, shared, finned heat sink 7" x 1 1/2" x 1 1/8".
I'm not planning on any sort of venting (it is unsightly in a cherry enclosure) but could put holes in bottom, sight unseen. Anyone have experience with this chipamp - will it generate too much heat that needs to be dissipated with ventilation? From reading the postings, my selected heat sink ought to do a fine job given a reasonable ambient temperature, but... the issue is where does the heat in the enclosure go? |
#2 |
Ransom:
You'll be fine if the heatsink is mounted externally. If the heatsink is enclosed, all bets are off. cheers, m |
#3 |
OK, small wood enclosure, no venting, heatsink exposed to outside.
How about that big old 330va Avex toroid poer tranny - does it need venting? Does it get hot? |
#4 |
Some vents on the bottom plate/chassis toward the front end and some vents on the back...will create an airflow towards the back from the front side...
SivanandBalan |
| Venting sub out bottom... | Godzilla | Subwoofers | 0 | 5th August 2008 10:55 PM |
| Horn mouth venting to the floor | Tyimo | Full Range | 8 | 22nd February 2008 06:53 PM |
| Venting options for TMM 2.5 way | Dave Bullet | Multi-Way | 2 | 15th January 2007 06:59 PM |
| It must be a conspiracy!/venting | Jocko Homo | Everything Else | 108 | 9th December 2002 01:41 PM |
| Page generated in 0.07799 seconds (65.50% PHP - 34.50% MySQL) with 10 queries |
