| Chip Amps Amplifiers based on integrated circuits |
i have to ask a very important question. i have a +-41VDC power supply on hand its the only one i got that is already in DC volts the maximum rating for supply for the chips i am using (opa541) is +-40VDC. i dont want to ruin any chips so i was wanting to know if there is a way i could get rid of a few volts without doing any unwinding of the transformer.
#2 | |
There are quite a few ways to drop a few volts. You coud use a pair of regulators and drop the voltage into a more suitable range, or even add a few diodes in series on each rail to keep the voltage down just a bit. Personally I'd go for the regulated approach, but thats entirely up to you.
If you take something apart and put it back together again enough times, eventually you will have two of them. |
#3 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 | |
Banned
Voltage goes down. Just a few turns is usually enough to drop some volts. |
#5 |
the thing is its not a toroidal so winding would be complicated
| WTB: pwer transformer for my aikido build | wendell | Swap Meet | 0 | 12th February 2009 03:58 PM |
| Pwer supply for ZV9 | dviswa | Pass Labs | 3 | 6th August 2006 03:05 AM |
| noob pre/pwer amp recording ?s | ghola | Tubes / Valves | 0 | 20th February 2006 06:38 AM |
| Pwer Supply Question | rafalc | Tubes / Valves | 2 | 1st October 2003 11:24 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.09397 seconds (66.47% PHP - 33.53% MySQL) with 10 queries |
