| Chip Amps Amplifiers based on integrated circuits |
I’m building a class D amplifier using the LM4651 and LM4652 chip set I intend to provide two full range and a subwoofer/ low pass channel. Power will be provided by three separate toroidal transformers to avoid crosstalk and something like 30 and 18 odd thousand uF on the board which I hope will stabilise it without regulators. Any comments on this are welcome.
I’ve simulated a filter system which seems to work quite well which hopefully I can post here somewhere, but how does this affect the input resistance the main amplifier is required to see or match with the “values” of R1, R2 (not their ratio) and RLP, CLP should they be removed with such an active filter? Is this a good way to take a low pass from a stereo signal? Any has anybody please got any ideas on how to implement a volume control on such a beast? Cheers from spud
#2 |
I suggest that you move your thread to Amplifiers - Class D forum, im sure you will find more help there than here.
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa |
#3 |
tried that and had absolutly no replies in ages, don't know what i'm doing wrong
#4 |
Which i could help but i dont know anything about class D. try asking less questions at once, and more specific ones. (lazy
#5 |
cheers mate, I'll try that
#6 | |
Basically, you will need 1 volume control between the source and your filter stage. Then you will need 3 controls (you can use trimmers if you want) to vary the sound level coming out of each power amp. You adjust the 3 controls to match it so it sounds right and leave those alone, and just use the 1 single control everyday.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#7 |
will there not be a lot of noise on the output if i remove the signal but the gain remains the same. I thought i had to attenuate the whole lot on the OP but this would create a lot of heat and theirs where i get confused.
#8 | |
#9 | |
I think it would help if you posted a legible schematic As far as I can make out you have two low pass filters per channel, and you've connected the outputs of two of those together, presumably for the sub-woofer. That won't work. Remove one of the op amps for the sub output and bring the input 1k resistors coming from the filters together to the inverting input of the remaining op amp. You can actually save some components by adding the channels first, and filtering the sub-woofer after the adder. Same end result. In general, a reasonably well designed filter will produce neglible noise at power amp signal levels, so I don't know what you're worried there. Rune
Do wizards use spell checkers? |
#10 |
Any reason you dont want to use the examples in the datasheet?
Im probably just going to make the PCB given in the datasheet as thats the easiest... Only problem is there are no drill holes in their pcbs.. (anyone know if they have eagle files for these examples?) Oh and the Reference PCB would be the one for a subwoofer right? thx |
| LM4651/LM4652 class D amps | lawbadman | Class D | 30 | 10th April 2007 04:31 PM |
| LM4651/LM4652 replacement | rtarbell | Class D | 5 | 15th May 2006 01:40 AM |
| PCB for LM4651/LM4652 | soundNERD | Chip Amps | 4 | 29th May 2004 06:54 PM |
| Lm4651 | soundNERD | Chip Amps | 11 | 22nd October 2003 03:13 AM |
| LM4651/ LM4652 power supply | audioaction | Chip Amps | 0 | 17th October 2003 02:55 AM |
| Page generated in 0.12743 seconds (73.30% PHP - 26.70% MySQL) with 11 queries |
