Old 18th March 2005, 02:53 PM   #1
Send a message via Yahoo to psychosteve
Default stk4231 bridge
can anyone rearange the circuit to bridge this chip, or is it easyer to build it as is and use an opamp inverter to power the bridge???
cheers guys, steve.. ..
you all laugh because im different, i laugh because youre all the same.. ..
Old 20th March 2009, 10:52 PM   #2
Send a message via AIM to shon35us Send a message via MSN to shon35us Send a message via Yahoo to shon35us
Default HMMM
Your not alone I have the same question, so I bought 2 chips hoping to get about 2x225w each one in BTL mode
Old 21st March 2009, 09:39 AM   #3
Are you aware that the STK4231 is designed for 8 Ohm loads? That means you need a 16 Ohm speaker, if you want to bridge two channels.
If you want 200 W into a 4 Ohm load, use two channels in parallel. If you want 200 W into an 8 Ohm load, bridge/parallel four channels or use the STK4050 or build a solid state amplifier or buy a PA amplifier, which will turn out cheaper.
In either case, find out, what the use of 200 W is, before you start.
Bridging works like with any other amplifier. There are several ways to do it. This is the simplest.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 29th June 2011, 04:20 PM   #4
I have stk4231 so should i use 8 or 4 Ohm speaker to get 100w per channel?
Old 29th June 2011, 04:36 PM   #5
kevinkr's Avatar
See post #3 above for your answer..
www.kta-hifi.net
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 07:22 PM
Stk4231 Ii Sammich Solid State 2 2nd July 2007 07:17 AM
My GC STK4231-2 Subwoofer amp, should I switch to discrete? EWorkshop1708 Chip Amps 5 27th December 2004 11:14 PM
Adjustable gain control for Sharp SX-9680/STK4231 II rkc7 Solid State 0 31st August 2004 04:44 AM
Stk4231 Pcb. Ford_V6 Solid State 1 25th May 2004 07:49 PM
Page generated in 0.07671 seconds (74.62% PHP - 25.38% MySQL) with 10 queries
