Old 17th March 2005, 08:10 AM   #1
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Default transformer VA
I'm beginning an LM3875 project. I've read over many of the archieve threads on tranformer selection. It looks to me like 160VA should be more than adaquate for a stereo amp, yet many choose a larger unit. Is there any empirical reason to go larger? I'm specifically looking at the 22v 160va Avel from PE. I also want it small because I want to squeeze it into the smallest possible chassis.
thanks!
Old 17th March 2005, 12:38 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
160va is enough (IMHO) for a good stereo Gainclone.
Larger transformers may have an advantage for reasons that I will not state here.
BUT, and I welcome comments from others here, I have found larger transformers to be a little noisier (ie louder hum).
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 17th March 2005, 01:01 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
You could manage with a smaller transformer. Think average power outtake. I think down to 80 VA isn't too wrong.
/Per-Anders (my first name) or P-A as my friends call me
Old 17th March 2005, 01:13 PM   #4
pinkmouse's Avatar
I have a mono LM3875 running from a 30VA 18-0-18. It's used as a loudspeaker test amp, but goes more than loud enough for most uses.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 17th March 2005, 01:17 PM   #5
chris ma's Avatar
Default Re: transformer VA
thanks!
For mee.-self anyway
I picked larger ones so that it can be recycled for other projects in the future. There is not much different in the $ amount for higher VA, but the trouble of looking/buying one and wait for it.. the delivery time....
The Butcher
Old 17th March 2005, 02:13 PM   #6
mod_evil's Avatar
Send a message via MSN to mod_evil
As i transformer VA to Ampers?
I have 127v in the frist and 15-0-15 em second.... of transformer.
Thanks.
Old 17th March 2005, 03:35 PM   #7
sam9 is offline sam9  United States
sam9's Avatar
You would think VA=Watts but it doesn't. On the other hand that's a way of thinking about it that may be crudely useful. I think it is more accurately considered a thermal rating -- the higher the VA the cooler it remains. Not surprisingly there is a relationship between weight and VA.
While you could determine the VA rating needed to drive the amplifier with a continuous (i.e., day after day non-stop) sine wave at max power as a way to ensure the VA rating is totally adequate-- as a practical matter, normal (or even vigorous) home use requires rather less than that.
Dopes the above sound vague? Good choice of transformer VA rating is a bit vague by nature.
Old 17th March 2005, 06:21 PM   #8
A lower VA rated transformer will have a lower voltage at the demanding peaks of the audio signal which is when the voltage is needed most. While I agree that a transformer wouldn't need to push that current continuously but it still has to maintain desired voltage when the peak current is required.
When you think about it there is not much difference in price of transformers to go up a size or 2 just to be safe. Personally, I don't want to skimp here.
Old 18th March 2005, 06:16 AM   #9
kmj is offline kmj  Sweden
kmj's Avatar
A wise choise, for as someone in the tube-forum said "You don't just build ONE amplifier"
Old 18th March 2005, 10:06 AM   #10
djk is offline djk
djk's Avatar
I used an 80VA 18-0-18 to run a stereo amp with 8 ohm speakers. It sounded a bit 'thin' when driven hard.
Changing to a 160VA 20-0-20 gave a much better sound.
Even though the AC voltage was higher, the DC voltage was about the same with the 160VA unit because it had better regulation.
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.11302 seconds (78.15% PHP - 21.85% MySQL) with 10 queries
