small amp (20-30watt) for fullrange project
Old 15th March 2005, 08:09 AM   #1
wuffer is offline wuffer  Denmark
Default small amp (20-30watt) for fullrange project
can anyone recommend a small amp about 20-30 watt, easy to make.. i was thinking of making speakers for my pc and i would like to try the fullrange...
Old 15th March 2005, 09:25 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Perhaps you cannot 'see the woods for the trees'!
A chip amp is what you want and you are welcome to start looking here
Then follow the GC web ring and you will have all the information that you need.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 15th March 2005, 09:28 AM   #3
thanks... just that site i was looking for...
so many designs.. what should i go for...
Old 15th March 2005, 09:32 AM   #4
Nuuk's Avatar
My suggestion would be an inverted design using a buffer. Buffer choice is down to what you feel comfortable building, they all sound very good with a GC.
All the designs on my site use the LM3875 but I ahve just built one with an LM3886 that sounds very good too. etails will be posted on DD when I have time.
And don't forget, if you are not happy to build from scratch, there are several people offering PCB's and/or kits.
Old 15th March 2005, 09:58 AM   #5
thanks.. i think im going to build it from scratch..
it dont seem very expensive so im going for it
Old 15th March 2005, 01:07 PM   #6
mod_evil is offline mod_evil  Brazil
mod_evil's Avatar
Send a message via MSN to mod_evil
Why you use the LM1875 for 20w and LM3875 for 50 ~ 60w ?
Old 16th March 2005, 04:56 PM   #7
what should i use for a volume control??? im going to build it in the same case... nothing fancy or expensive.. only going to use 1 input....
im not sure if i should go for the LM3886 or the LM3875. the price is the same.. going to make a amp for a small 6 inch sub
Old 16th March 2005, 06:02 PM   #8
Nuuk's Avatar
Use the LM3886 for a sub, it will give a bit more power.
And if this is for a sub, any pot will do. Try a 20K or 50K log. If you want specific recommendations, then search this forum.
Old 16th March 2005, 06:05 PM   #9
thanks.. then i will get 2 LM3875 and 1 LM3886
it was for the stereo amp.. but i will search som more
Old 17th March 2005, 03:08 PM   #10
mod_evil's Avatar
The datasheet specifics one pot 10k
small amp (20-30watt) for fullrange projectHide this!Advertise here!
Best small fullrange for AM radio Foxx510 Full Range 22 18th September 2008 06:47 AM
How should I fill/stuff/line my small sealed fullrange sphere? GuyPanico Full Range 3 9th August 2007 02:15 PM
Can anyone recommend a small 10-30watt DIY amp? rurockn Chip Amps 6 13th October 2006 03:39 PM
small fullrange driver help Pepe Full Range 6 28th July 2006 05:30 AM
Small fullrange mounted in dash Techz Car Audio 0 20th March 2006 02:07 PM
Copyright ©1999-2017 diyAudio
