| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I saw the LM1876 (http://cache.national.com/ds/LM/LM1876.pdf) schematic on page 2 and compared it with LM1875's (http://cache.national.com/ds/LM/LM1875.pdf) on page 1... LM1876 have a MUCH lesser part count... there's no input cap... no resistor to ground at the input... Can i safely use this schematic for LM1875? What would the input impedence be then? LM1876 is a stereo version of LM1875 right? Just like what LM4780 is to LM3886?? Thanks! Cheers!
#2 |
Hi!
you are right that teh lm1876 are the dual version of the 1875. i have not looked at the datacheets, but since they are the same chip, using either circut will work, they are only opamps remember.. 56k is a nice standard for input impedans btw. and keep the imput cap, at least until you have made certain you have no dc offset from your source.. i like to keep them there for safty resons anyway. |
#3 |
Hi there.......watch the layout with these ic's.......duff psu return v.s sig ground = high thd....the low sig/ noise ratio is attractive.....when circuit well designed these ic's can produce good sound. I've even used them as power headphone amps, (with a relay in the o/p to delay start and quick off to avoid plops) although one can just make out the hiss.
richj |
| LM1875 and questions regarding the example application in the datasheet | aempirei | Chip Amps | 24 | 1st July 2010 07:02 PM |
| My Home theater with LM1876, LM1875, LM3876 For Dummies | Paswa | Chip Amps | 16 | 4th March 2008 05:06 AM |
| LM1875/lm1876 single supply? | Adam M. | Chip Amps | 16 | 7th February 2005 02:06 PM |
| LM1875 schematic... | w00t | Chip Amps | 7 | 20th December 2004 02:56 PM |
| the best PCB design and schematic for the LM1875? | lutherblisset | Chip Amps | 0 | 29th October 2004 01:40 PM |
| Page generated in 0.07133 seconds (71.71% PHP - 28.29% MySQL) with 10 queries |
