| Chip Amps Amplifiers based on integrated circuits |
Dearest Gurus,
may I humbly ask which is better to either to use a buffer (opa627) or simple pre (opa627 with 2 or 3 gain) to feed parallel 4780 ?. Thank you very much most regards p/s: I am using CD63 as the source. |
#2 |
Electrons are yellow and more is better!
What is the difference between the alternatives? Do you need a buffer at all?
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Thanks for reply but, pardon me, I did not understand your reply
English not my first language.Must I use single buffer (OPA627 without gain) or may I use simple pre (OPA627 x 2 or 3 gain without BUF) to feed my LM's (parallel chip) and why you said so ?. Thanks for your explanation. Most regards |
#4 |
A buffer is usually used very close to the amp and possibly with a low pass filter between it and the amp.
A preamp may use the same circuit but is separate to the power amp and used to drive the interconnects that join the two, or provide some extra gain. What's best? It depends on your system and how it is configured. For simplicity, ie a single 'box' and fewer connections, putting the volume control and buffer in the same box as the power amp is a good idea. But you may wish to put your power amps right next to the speakers. In that case, a separate preamp is preferable.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#5 |
Thank you - thank you Sir Nuuk
#6 |
I wish that my bank manager called me Sir!
#7 | |
#8 | |
Was it just me NOT thinking audio right now? |
#9 | |
#10 | |
Or maybe they would rather people borrowed more to buy more commercial stuff... the jury's out |
| Simple Volume/Buffer! | amplifierguru | Solid State | 37 | 6th September 2010 06:41 PM |
| Simple Input Buffer | Adam M. | Chip Amps | 17 | 1st May 2010 12:37 AM |
| Simple Low Distortion JFET Buffer | wrenchone | Solid State | 21 | 29th January 2007 08:16 PM |
| Simple buffer for balanced inputs? | Nisbeth | Solid State | 6 | 25th October 2005 06:24 PM |
| simple line buffer | fscarpa58 | Tubes / Valves | 14 | 9th December 2003 08:30 AM |
| Page generated in 0.11011 seconds (66.73% PHP - 33.27% MySQL) with 10 queries |
