| Chip Amps Amplifiers based on integrated circuits |
i am building a chipamp using the lm4730's bridge schematic in the datasheet i was just wondering if anybody else ever attemted it and has any oppinions or anything
#2 |
If you want more power, why not try an lm3875 or lm3886.
They are much easier to use than a bridge circuit. Plus they have higher output levels, and I'm sure higher sound quality. But if you have the parts you might as well try building out and deciding for yourself |
#3 | |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 | |
I don't know... Look on page 5 of the lm4730 datasheet, theres a bridge circuit. |
#5 |
I didn't even know if they make LM4730 (as Digi Key show no link). Why use 14W amp bridged, when you can use 60W amp in stereo?
#6 |
well i have a 15 volt 5 amp already built power supply all i gotta do is build an amp good for that power and i figured the lm4730 would be a pretty nice matchup unless anybody else has a better idea for me
#7 |
15V single supply, +/-15V supply, or +/-7.5V supply?
If its a +/-15 supply, you should go for a lm3875 or lm3886. For a +/-7.5, go for a Texas Instruments OPA549 or 541. If it's a 15V single supply, you should be able to use an OPA549, but I don't know how to do it. I tried building one to run off of 12VDC, and it sounded horrible, as in distorting with everything. I thought it may have been caused by low voltage, but I hooked it up to a 40VDC supply, same result. I know it can be done, though. In fact, I'll start a post on that... |
#8 | |
http://www.national.com/ds/LM/LM4730.pdf
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#9 |
SoundNERD don't let them get you down. Some of the most highly regarded amplifiers in the world put out single-digits of Watts, max. If this is what you want to do, listen only to those who will help you actually *do* it.
Jesus loves you. |
#10 | |
Yes, I know that. Like the LM3875. Only 56W but the sound is amazing and powerful, as in better than my 100W RMS x 6 Yamaha reciever (which was much more money too!!). And I know some tube amps only produce 4 or 5 watts of power. In general, watts means nothing to me (except in certain situations, such as comparing a 250mW 386 amp to a 56W 3875 amp. But when you see a 200W x 2 amp in a store, it can't even come close to my 56W x 2 3875 amp. |
| CDPRO2 Group Project (open source project) | BrianGT | Digital Source | 147 | 8th August 2008 11:37 AM |
| My OLD Project....... cheap tube audio project!!! | tube-lover | Tubes / Valves | 4 | 8th May 2008 09:26 PM |
| New OB project | Geoff H | Full Range | 18 | 16th September 2007 11:14 AM |
| My first project, cool project. | sorinsistem | Solid State | 3 | 19th January 2006 05:08 PM |
| Page generated in 0.11560 seconds (71.34% PHP - 28.66% MySQL) with 11 queries |
