| Chip Amps Amplifiers based on integrated circuits |
I have my gainclone with 37.5vdv from the rectifier, so it is good for 8ohm speakers, but I want to try to put the two positives together and the two negatives together , kinda bridging to use it as a sub amp in my room for a little bit, I want to see how my sub would sound in my room. My sub is an e13kv.2 and has dual 2 ohm vc. I have them in a series to have 4ohm, but can my amplifier work when "bridged" on a 4ohm speaker?
Thanks, Josh |
#2 |
what chip are you using?
#3 |
this is for Brians new 3886
#4 |
That's not bridging, it's paralleling. It will work, but you will need to put load sharing resistors on the outputs to avoid current hogging and "Bang!"
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
So pretty much I can't try out my sub in my room with my GC?
Thanks Guys |
#6 | |
#7 |
Try it with just one channel, it may be louder than you think. But make sure you have a decent heatsink!
#8 | |
| Impedance Matching | maxzimum | Solid State | 2 | 9th April 2009 02:03 PM |
| Help with Impedance Matching | mudihan | Pass Labs | 6 | 14th July 2006 10:35 AM |
| impedance matching to a pro amp... | MyNameIsJake | Solid State | 2 | 4th June 2006 05:32 PM |
| Need help understanding transformer impedance ratios and impedance matching | percy | Tubes / Valves | 5 | 28th February 2005 08:35 PM |
| Impedance Matching | bryce66 | Solid State | 6 | 9th November 2001 09:02 AM |
| Page generated in 0.10614 seconds (72.26% PHP - 27.74% MySQL) with 10 queries |
