| Chip Amps Amplifiers based on integrated circuits |
When I turn on my light while my music is playing, I hear a plopping noise coming from my speakers. At first I thought it was aproblem with ground in my house, so I disconnected the earth from the power distribution block. But this did NOT solve the problem, it just keeps plopping.
Any other gainclone owner who has this problem too? |
#2 |
Yes, same 'problem'. Happens also with a commercial amplifier (Hitachi integrated, circa 80s).
#3 | |
It is getting weirder: I've run both monoblocks and the pre of an UPS which was not connected to any AC outlet (purely on batterie power), I turn on the light: PLOP Is this still normal? |
#4 |
Radiated RF noise. Check all your cables are screened properly. Other than that, try a 0.1uf cap across the input pins on the chip.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
Does the cap have to be on the chip or can I put it also on RCA connector (connecting the positive to the negative side)?
#6 |
The cap must sit directly at the positive and the negative input pin.
Nationals recommendation is 220pF for the LM3875. Look here, page 4 and top of page 6: http://cache.national.com/ds/LM/LM3875.pdf Regards Franz |
#7 |
Or what about doing something about the light switch that is causing the RF?
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#8 |
Thank you for all the suggestions, I'll try putting the 220pf cap between pin 7 and 8.
This won't be easy, I guess because all the components are already soldered to the pcb. Nuuk: I guess I could listen to the music in the dark
#9 | |
But if you get afraid of the dark, I think you can put a capactior across the switch contacts to get rid of the RF thatit generates. Perhaps somebody more knowledgable can comment on the exact cap required.
#10 |
This is probably a stupid question but I'm going to ask it anyway: is there an other way of saying 220pf. e.g. 2,2uf or 0,22mf
I can't find 220pf on the RS site |
| Hi All in the EARTH | zeonrider | Car Audio | 0 | 30th December 2006 05:29 PM |
| noisy noisy noisy noisy noisy tube | dsavitsk | Tubes / Valves | 50 | 20th February 2006 04:07 PM |
| Earth again | Pbassred | Solid State | 20 | 10th July 2005 07:44 AM |
| How on earth...? | Nuuk | Chip Amps | 4 | 6th April 2004 01:55 PM |
| Should I come down to Earth ? | Prof | Chip Amps | 19 | 12th June 2003 02:05 PM |
| Page generated in 0.10234 seconds (77.82% PHP - 22.18% MySQL) with 10 queries |
