| Chip Amps Amplifiers based on integrated circuits |
#11 | ||||
Did it Himself
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#12 |
I dont apear to have read you reply very well.
Thank you for your advice. I'd better get on with building them... [edit]: I've updated the diagram to check i've got the right idea.
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#13 | |
Banned
You have an input buffer now. Also, you will optimize dc-offset if instead of connecting NI directly to ground you use a resistor. That resistor value should be the parallel combination of the other three resistors. |
#14 |
Did it Himself
Agree with that. Also I'd put the 100 ohm resistors on the outputs of the left and right lines as well. 22k would also be a good value of input impedance for your new input buffers.
#15 |
Ok, i've made some changes, and ringed them as the diagram is quite large... Is everything i've changed ok?
[edit]:forgot the image...
#16 |
Did it Himself
Looks good but those 10k resistors on the output to ground are redundant.
#17 | |
Banned
The chips need a path to ground when there's nothing connected on their outputs. |
#18 |
Did it Himself
Why is that Carlos? In the dozens of such circuits I have built it has yet to appear a problem. Sure the input if floating needs them to provide bias current, but I don't see why the output needs them.
#19 | |
Banned
It needs a return path. Just try what happens when an op-amp has it's output(s) floating. Touch the op-amp with your finger and feel the heat.
#20 |
What heat? I've never noticed any.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| I need an active sub filter! | hernanstafe | Subwoofers | 18 | 4th December 2007 09:32 PM |
| zobel network and series notch filter | djmann02 | Multi-Way | 1 | 9th January 2006 12:06 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| Many Op-Amped Active Crossover Network | Matttcattt | Chip Amps | 2 | 22nd June 2004 09:35 AM |
| Low-pass filter network for mini-array | 7V | Multi-Way | 23 | 26th July 2003 12:11 PM |
