Opa549
Opa549
Old 16th February 2003, 03:07 PM   #31
protos is offline protos  Greece
protos's Avatar
Hi Jazz,
I got one channel working perfectly.I originally had the same problem till I realized that I hadn't connected the Ref pin to ground(I used no current limit).So Ilim pin is connected directly to Ref and they are connected to Ground.Enable pin is open.I had problems though with the other channel because it was giving me about 4-5V of offset and I didn't manage to get it right.I have ordered some more samples in case I managed to damage that one although I don't see how with all those safety features they have they should be practically indestructible.However this gave me the chance to substitute a LM3875 on hand and make some interesting A/B comparisons.
Overall I would say my preference went to the 549.More neutral,less peaky in the upper mids and more power and control.
More testing is in order since they haven't broken in completely yet.
Old 16th February 2003, 05:02 PM   #32
JAZZ2250 is offline JAZZ2250
JAZZ2250's Avatar
Indeed, I didn't connect the Ref pin to ground. Now, OPA549 with unity gain works. Next, I'm gonna give some gain to it. Thanks, protos.
Old 17th February 2003, 11:36 AM   #33
carlmart is online now carlmart  Brazil
Default Parallel
Has anyone paid attention to this parallel arrangement suggested on the OPA549 data page?
Would it work for a power amp?
It's interesting to note that there's no power amp circuit suggested on the data. I wonder why.
Carlos
Old 17th February 2003, 05:26 PM   #34
partyjups is offline partyjups
Question parralel/bride of opa549
http://focus.ti.com/download/trng/do.../sigcond_5.pdf
page 20 the super power amp.
Have any body build this circuit used for audio.
does the resistors have to mached ?
It look very simple I wonder if the parralel side will "fight" and get very hot.
jc dk.
Old 17th February 2003, 06:47 PM   #35
Default TI parallel circuit
The reason I was asking for comments over that OP549 parallel arrangement, is because they do not a very good thing, as pointed up to me by Kuei Yang Wang over a bridging circuit I had seen.
The output of amp A1 feeds the input of amp A2, which means it's feeding distortion and all that.
Once again, it was no suggested specifically for audio. So I wonder.
Carlos
Old 17th February 2003, 06:53 PM   #36
till is offline till
Banned
why should one parallel them? isnīt 8 or 10 A enough? If you really need more, use some paralleld really big sourcefollowers behind them?
Old 17th February 2003, 07:00 PM   #37
Default Parallel
No, I have nothing against paralleling amps. I even opened a specific thread on this Forum willing to discuss bridging and paralleling gainclones.
What I don't know is if this way suggested by TI, different from the one I knew and also suggested by National, was a valid one audio wise.
Carlos
Old 18th February 2003, 12:15 PM   #38
Rookie is offline Rookie  Serbia
Rookie's Avatar
Protos,
How much is the capacitance in the power supply you used? I know that OPA549 has less PSRR than LM3875.
Old 28th February 2003, 05:34 AM   #39
JAZZ2250's Avatar
Default Heatsink
have to drill a lot of holes?
10 holes per OPA549...
I tried making a prototype heatsink with an aluminum plate measuring 9x4x0.25". I copied the mechanical drawing to PPT and adjusted its size to exactly the same as shown in the drawing. Then I printed it out on a paper, cut it, pasted it on the aluminum plate, punched, then drilled 10 holes using drill press. The whole process could be done in 10 to 15 minutes except for the making taps for mounting the amp. Before installing the amp to the aluminum plate, all the pins were masked (insulated) with heat-shrinkage cable cut to the 2/3 of the length of the pin.
In short, drilling holes is not so much time-consuming and you have enough area, which will contact the amp, for heat transfer. If you can find a heatsink for TO3 devices without any pre-drilled holes, you have no problem.
I'll post some photos if you're interested.
Old 28th February 2003, 07:38 AM   #40
ThingyNess is offline ThingyNess  Canada
Send a message via ICQ to ThingyNess
The reason for paralleling them is not so much for current, but for power dissipation reasons. If you run those opamps with 8A with their maximum supply voltage for any length of time with any voltage across them (like in a linear amp), they will go into thermal shutdown and not work well. Paralleling them makes the effective allowable power dissipation be equal to the sum of the power dissipation ratings of the opamps, and will allow for greater output power.
Opa549Hide this!Advertise here!
Opa549 Treefingers Chip Amps 1 23rd September 2005 08:37 PM
Fs: Opa549 bigmike216 Swap Meet 3 26th August 2005 12:08 AM
OPA549 GC for Car rehanabid Chip Amps 11 13th June 2005 04:09 PM
Opa549 ctardi Chip Amps 6 8th May 2005 07:43 PM
