Old 9th March 2005, 08:40 PM   #1
Default problem with LM's and power supply
Hello,
i have one transformer 2x24V and i want to supply one LM3875 chip and one LM1875 the same time.
because a 2x24V trafo gives us around +-35V and lm1875 can go max +-30V i am using regulator LM350..
When i power up each channel alone everything is ok.. but when i power them up together there is a terrible huge very loud noise comes out from both channels..
i suspect some ground loop because input grounds are connected together but power grounds one goes inside regulators the other is from the rectifiers directly from transformer..
i have draw the schematic i am using trying to explain my connections...
what am i doing wrong? any suggestions?
thank you very much!
Old 9th March 2005, 09:42 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
I see the power grounds connected to the input ground.
/Hugo
Old 9th March 2005, 10:13 PM   #3
if you talk about the green line its just to notice that the preamp connects the input grounds together....
on the amps pcb there is a star ground of input ground with power ground... but they are also connected inside the preamp.
i think that there is something to do with the regulators..
any clue?
Old 9th March 2005, 11:17 PM   #4
moamps is offline moamps  Croatia
Hi Kostas,
I see two mistakes in your schematic. First, you can't mix secondaries and their respective bridges. In other words, if you use one secondary to get positive voltage for one amplifier, the same secondary must be used to get positive voltage for the other amp (not negative). Second, in your configuration, you can't use a positive regulator (LM338) to get negative regulating voltage but a regulator that's normally used for getting negative voltage (with common pin connected to ground).
Milan
Old 10th March 2005, 10:18 AM   #5
i have put the positive with the positives the negatives with the negatives.... the same problem..
i have done another test.. i powered both amps .. and i connect only the one input at a time and it is working... the problem starts when both inputs are connected.
i remind you that the preamp connects grounds together from inside. so i can think that this is the problem..
the common input ground of the preamp..
what can i do to fix it?
the regulator with LM350 works fine my friend.. this is a schematic i found here in the forum from another great guy.
what can i do :-( im so sad :-(
Old 10th March 2005, 10:37 AM   #6
shusha is offline shusha  Croatia
shusha's Avatar
Send a message via ICQ to shusha
Why not zz, he can use positive regulators for both sides as long as he have two secondaries (if this two secs. are from same transformer as you mentioned). I am sure you know that. His schematic with 338 looks like Pedja's. I have built several regulated PSU's by it's schematics.
http://users.verat.net/~pedjarogic/audio/index.html
Old 10th March 2005, 10:49 AM   #7
Frank Berry's Avatar
Look at your power supply schematic very carefully. On the -35 volt supply, the cathode (+) end of the bridge is going directly to common ground. On the -25 volt supply, the cathode (+) end of the bridge is going to the input of the regulator. This will not work because you are shorting out the regulator.
You must use a negative regulator if you expect the two amplifiers to work from common windings.
Frank
Old 10th March 2005, 12:02 PM   #8
Originally posted by shusha
...Why not zz, he can use positive regulators for both sides as long as he have two secondaries......[/B]
Bok, Hi,
Frank je dao odgovor.
Look at Frank's post.
Pozdrav, Regards,
Milan
Old 10th March 2005, 12:07 PM   #9
Electrons are yellow and more is better!
peranders's Avatar
... so if you want to use only positive regulators you must have at least 3 totally separate windings and if you fix a true negative regulator you can get away with only two secondary windings.
/Per-Anders (my first name) or P-A as my friends call me
Old 10th March 2005, 12:19 PM   #10
....or (wierd solution) keep amps grounds separated and use ground-lifted line transformers in inputs..
Power supply problem Niila Tubes / Valves 6 12th April 2008 01:39 AM
Power Supply problem Landoctor Chip Amps 3 8th September 2007 07:50 PM
Power supply problem krzanik Tubes / Valves 19 1st May 2007 03:56 PM
Power supply problem PassFan Tubes / Valves 6 24th October 2003 10:03 PM
Power supply problem (or something) ir Chip Amps 4 23rd August 2003 08:44 AM
Page generated in 0.13049 seconds (74.05% PHP - 25.95% MySQL) with 11 queries
