| Chip Amps Amplifiers based on integrated circuits |
I was wondering if anyone would be kind enough to share a 16mm dual pot eagle footprint
#2 |
Hope this fits your needs:
#3 |
thanks mate..i really appreciate your help..they were exactly what i needed
#4 |
Glad to help
#5 |
Banned
Alcaid.. Are you a eagle Pro or just really good at it ?
#6 |
No, just learned by playing around with it.
#7 |
mate, would you k now how to do those huge ground planes in Eagle??
#8 |
Banned
DAM some one is hovering over me because i wanted to ask the same question but to turn the ground plane OFF : O )
#9 |
It's just to draw the polygon with the polygon tool (looks like a chewed off square).
Draw the outer lines of the polygon and then rename it using the name tool (resistor with R2 over). Use the rename tool to find the name of the net you like to use the plygon for, and the rename the polygon to the same name. You then get asked for the name of the spliced net. Just choose in the list. Finished! |
#10 | |
If you want to remove a polygon just use the delete tool (big X) and delete the corners of the polygon. |
| Eagle part for dual Jfets like the 2SK389? | Bricolo | Parts | 5 | 17th February 2005 09:26 AM |
| LM3875 PCB Footprint | Doovieman | Chip Amps | 1 | 9th June 2004 07:39 AM |
| LM4780 Footprint.. | Paprika | Chip Amps | 2 | 12th April 2004 07:17 PM |
| Page generated in 0.47485 seconds (14.67% PHP - 85.33% MySQL) with 11 queries |
