Banned
Joined 2002
Banned
Joined 2002
It's just to draw the polygon with the polygon tool (looks like a chewed off square).
Draw the outer lines of the polygon and then rename it using the name tool (resistor with R2 over).
Use the rename tool to find the name of the net you like to use the plygon for, and the rename the polygon to the same name.
You then get asked for the name of the spliced net. Just choose in the list. Finished!
jleaman said:DAM some one is hovering over me because i wanted to ask the same question but to turn the ground plane OFF : O )
If you want to remove a polygon just use the delete tool (big X) and delete the corners of the polygon.
Banned
Joined 2002
Hello!
I saw you were talking about eagle.
Check this link:
http://www.interq.or.jp/japan/se-inoue/e_eagle20.htm
I printed it all, eagles own tutorial s***s
This guy describe in a different manner it's more right on target
Bjorn
Check this link:
Bjorn
SM2GXN said:Hello!
Check this link:
Bjorn
It's now bookmarked. Thanks for the link!
- Chip Amps
- Eagle footprint for 16mm dual pot
