| Chip Amps Amplifiers based on integrated circuits |
Hello,
I'm building a P2P GC based roughly on the BrianGT kit. One important variation is that I have some uninsulated chips. So now I've verified that the power supply is good to go. And I'm pretty sure I have the chip well-constructed. However, when I powered it up--without any signal input or output connectors, only power--I found a DC offset of roughly 7 VDC. Now, since the thing is uninsulated, the heatsink is carrying a nice charge of 37VDC, the rectified power supply voltage. So, now, I need to learn how to diagnose and verify what I'm doing. My best first guess is that I need to re-verify the P2P connections on the chip's pins. The second best guess is that I have a grounding problem. What, my brain wishes to resolve, is the most likely reason for a 7 volt DC offset? It isn't 34 VDC, nor is it 60mV. So, I have roughly seven stray volts. Orderly advice is greeted with thanks. Dave
I have a small website for my projects. |
#2 |
I would start by isolating your chips.
#3 | |
How are you planning to implement the uninsulated chip? Do you plan to leave the heatsink at V- and just insulate the whole heatsink from the chassis? Or do you plan to install insulators between chip and heatsink and have skipped that step for a trial assembly?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 | ||
In addition, there are no RCA connectors yet. Should I go ahead and install them for testing? I'm not quite there yet when it comes to understanding the NFB chipamp structure. I figured that having the circuit built would be fine for testing the power stuff. I didn't think that the signal circuit would have to be complete as well. Dave **edit** I guess my real question is how the uninsulated package is causing some sort of voltage problem, especially if the circuit is otherwise all OK.
#5 | |
So if you are telling us that your heatsink is at V- but it is not touching any part of the circuit, then all I can say is to keep checking your connections.
#6 |
A photo attached
black is V+, red is V- and white is ground. I'll double and triple check the connections and report back. Perhaps I'll build the other circuit to see if I have the same problem, eh? Dave
#7 |
I see 2 resistors not connected on one end. I assume 1 is the input resistor, what is the other?
#8 |
Uh...That is Ri, to connect the FB resistor to ground.
I'm just going to keep going down this road... So whaddya think? Should I connect that to the ground somehow? Dave
#9 |
So, you are building this picture:
If I had to take a guess, I would think that maybe you are not connecting SGND to GND? They need to be connected by a wire.
#10 |
Ok. That's helpful. I have been under the impression that signal grounds and power grounds should forever separate; I don't know where I got that idea, though. Now that I think about it, it doesn't make sense to keep them separate completely. Is there a rule of thumb where along the power paths to bring the two together?
| Odd tda1541 voltages / implementation | ash_dac | Digital Line Level | 1 | 26th July 2007 07:25 AM |
| Possible PCM2706 implementation | jaycee | Digital Source | 9 | 5th November 2006 11:14 PM |
| Help w/ diyAudio CCS implementation | arnoldc | Tubes / Valves | 24 | 29th June 2006 04:31 PM |
| My implementation of the Audidigit T-amp | Mick_F | Class D | 9 | 3rd October 2005 08:50 PM |
| My Kwack clock implementation | Andypairo | Digital Source | 14 | 18th January 2004 02:53 PM |
| Page generated in 0.14869 seconds (65.73% PHP - 34.27% MySQL) with 11 queries |
