LM3886 - What Transformer ?
Old 8th March 2005, 01:32 PM   #1
HarryK is offline HarryK  United Kingdom
Default LM3886 - What Transformer ?
Hi All
Sorry for the really stupid question but......
I have just bought one of Brians LM3886 kits and I now need to get a transformer.
I live in the UK and I bought a standard LM3886 kit (2 LM's and one PSU).
What type of transformer will I need and where is the best (not really the cheapest) place to get one.
And if its not too much trouble, what wires go where ?.
Thanks in advance.
H
Old 8th March 2005, 02:25 PM   #2
filholder is offline filholder  United Kingdom
Maplins do some very good torroidal pretty cheap.
I have just received 2 * 120va 22 volt one for my dual mono setup.
If you want they have larger but the prices are far cheaper than anything esle in the u.k. that i have found.
For example mine cost 30 for two delivered. Maybe you want the higher rated one but in the confines of the case i bought they were a no go. I think that 22v ones are the best and they have 120va and 160va which are ideal for the dual mono setup.
For the stereo kit maybe the 330VA 2 x 24V, but this might be a little high voltage wise.
Hope that helps
Phil
Old 8th March 2005, 03:05 PM   #3
ljk11 is offline ljk11  Trinidad and Tobago
I am interested in starting a gainclone also and would like to know what is a good transformer for 8 ohms use, available in the US
Old 8th March 2005, 03:14 PM   #4
mantisory is offline mantisory
I am wondering if a person can't step down the voltage a little in this case? BrianGT had said he was going to use the above mentioned tranny, and i myself have got a 2*30V (300VA) toroid. I hope this'll be okay for this application.
thanks,
Mantisory
Old 8th March 2005, 10:23 PM   #5
colinc is offline colinc  United Kingdom
Perhaps I got lucky but if you're not in a rush check out what's on Ebay. I bought four ILC 300VA torroidal transformers with dual 0-21v secondaries for 2.50 each a couple of weeks back. I have a set of Brian's boards/parts to go with them.
Unfortunately bathroom DIY has overtaken audio DIY but I'll get there soon!
Old 9th March 2005, 11:52 AM   #6
steenoe is offline steenoe  Denmark
steenoe's Avatar
That is definately too much. You will have to use the regulated supply for that trafo.
It is not advisable to use a trafo close to the limit of these chips.
I am using 2x18 volts and there is plenty of power. Furthermore, the amp can safely be connected to speakers rated at 4ohms, without getting sweat'y I would say 2x22 volts is about max.
Steen.
BTW You could also unwind the trafo to get the right voltage.
It is actually easier than it sounds.
Old 9th March 2005, 12:13 PM   #7
Isn't Brian's offering regulated? I thought so....if not, what are the MUR860's in the power supply? Or do you mean i'd need to further regulate it.
On the national 3886 spec sheet here , it says that the max power supply voltage is 84V, which is 42 per side?
I am not sure where the problem is...
Old 9th March 2005, 12:41 PM   #8
boholm is offline boholm  Denmark
boholm's Avatar
Originally posted by mantisory
. . . it says that the max power supply voltage is 84V, which is 42 per side?
30V AC * 1,4 = 42V DC - so you are practically on the edge.
Furthermore when a transformer is unloaded it gives out more voltage than indicated, so in practice you may get out more than 42Volts DC of your PSU - even when your LM3886 is connected, because it doesn't use much idle current.
If you have a voltmeter (multimeter), some loose resistors, a calculator *and* know Ohms law, you can test it for yourself - *always* be careful messing with transformers .
Best regards
Bo
Old 9th March 2005, 12:50 PM   #9
steenoe's Avatar
No. The Mur's are rectifierdiodes! Check the datasheet again regarding railvoltage/outputpower.
I guess if you want to run a 84 volt supply, you would need a speaker with an impedance of 30ohm or something like that. Impossible.
Steen.
Old 9th March 2005, 01:49 PM   #10
so...I bought this transformer thinking it would be the right one, but apparently i was wrong. Now what? Should i try a regulator circuit (based on the lm375 or something) or should i try to trade in my transformer?
LM3886 - What Transformer ?Hide this!Advertise here!
My LM3886 Stereo Amp. w 12-0-12VAC Transformer Andreq Chip Amps 27 1st May 2011 05:32 PM
transformer for LM3886 dual mono kit gonzalez Chip Amps 16 11th October 2008 09:55 AM
Transformer for LM3886 marcusdeming Chip Amps 25 10th January 2008 01:44 PM
LM3886 w/transformer $100 plus shipping nodiak Swap Meet 0 22nd July 2006 11:53 PM
Smaller transformer for lm3886 amp? ted Solid State 6 14th April 2003 02:41 PM
