Old 8th March 2005, 12:41 AM   #1
tkelley is offline tkelley  United States
Question NIGC 3875 Distortion?
I recenetly built one of BrianGT's standard 3875 kits with great results. It is much more pleasurable than my "Super Store" amplifier. I was so pleased with the results that I decided to build a set of GC's with premium parts to see if it made a difference. Upon completion, I exchanged the BrianGT board for my own and the sound was awful. The amp works, but the midrange distortion is horrible. I believe I copied the BrianGT PCB topography 100%. The signal ground 'SG' and common ground 'CG' both terminate back to a star ground. I checked all of the connections and double checked the component values. Everything looks good. Is is possible to have a faulty 3875 chip. Any help of what to look for is greatly appreciated.
Old 8th March 2005, 02:11 AM   #2
llmobll is offline llmobll  United States
Send a message via AIM to llmobll
well distortion can come froma variety of places so let me give you some points...
1. Check your grounding, most of an amps problems come from improper grounding issues.
2. Triple check your soldering points.
3. Clean off the excess flux.(Sounds stupid, but has solved soo many problems for me.)
4. Lastly... make sure your solderd joints are good, sometimes if a circuit isn't behaving correctly i take a iron to all the joints... remelting them and letting them settle again.
good luck
Old 8th March 2005, 02:21 AM   #3
Greg Erskine's Avatar
hi llmobll,
You did connect the LM3875 to a heatsink, otherwise SPiKe would have cut in, or have you mixed up the 220R and 22K resistors?
Greg Erskine
Old 8th March 2005, 02:30 AM   #4
jeff mai's Avatar
Your grounding scheme is different than BrianGT boards. If there are no obvious errors to fix, I'd start here.
Old 8th March 2005, 02:55 AM   #5
lazyfly is offline lazyfly  Australia
Trying to figure out a layout for a board too and am a bit confused now Did a p2p 3875 and had Signal attached between the 220R and 22k resistors. 22k to ground, 220R to pin 7. Your image appears to have the Signal running through the 220R then the 22k is attached to ground.
Click the image to open in full size. Click the image to open in full size.
Could that have anything to do with it because the p2p thing here works fine? Check the schematic in Brians User Guide to confirm.
*edit: Is chassis gnd connected to the chassis? Left that out accidentally and largely lost drums/bass which left mids and highs sounding a bit iffy.
Still don't understand all this so take little if any stock into what I say.
Good luck
Old 8th March 2005, 03:03 AM   #6
Good point. Power ground has to connect to signal ground somewhere, either on the board (like Brian's) or at the star ground.
Greg Erskine
Old 8th March 2005, 03:14 AM   #7
Bugger, that resistor layout shouldn't matter either way, should it?
Old 8th March 2005, 03:59 AM   #8
I was connected to quite a large heatsink. I believe the resistors are correct. The thing that was interesting is that the volume level was identical to my previous PCB, just with distortion this time. It also did not have the usual amount of heat production that my previuos 3875 chip had while burning in.
Old 8th March 2005, 03:59 AM   #9
This is confusing to me as well. Following the traces on the BrianGT PCB it appears that it is wired as follows. Correct me if I am wrong, but this is the layout that I copied.
Old 8th March 2005, 04:38 AM   #10
Okay I marked the image stupidly. My mistake, it's meant to be s-in at the bottom and pin7 at the top... whoops.
I'm assuming your reading it upside down/right way up Yes, your's is wired like that. signal > 220R > 22K - the schematic is signal > 22k > 220R. Thinking about it it shouldn't make a lick of difference (that's a question!) and yeah, your layout is the same as Brians pcb.
I like confusing the issue
Built a ESP P19 late last year using 3876's and that got really bloody hot for a few hours. The 3875 isn't getting hot at all and from reading past threads not all of them go through that excessive heat stage.
Rabbitz built Brian's kit and from memory that didn't get stupidly hot either.
Sorry for messing up that image
NIGC or IGC, advices needed. Dxvideo Chip Amps 3 11th April 2007 03:26 PM
NIGC input impedance xcortes Chip Amps 2 23rd December 2004 07:38 PM
Got some parts with my NIGC kit that I don't know what to do with TheDriver41 Chip Amps 12 17th December 2004 12:38 AM
NIGC Buffer Assesears Chip Amps 21 2nd September 2004 07:36 AM
Wiring preamp and NIGC miguel2 Chip Amps 5 30th December 2003 04:53 PM
Page generated in 0.14410 seconds (69.52% PHP - 30.48% MySQL) with 10 queries
