Old 6th March 2005, 02:59 PM   #1
Send a message via MSN to audiocrazy_pune Send a message via Yahoo to audiocrazy_pune
Post Building LM4780 Multichannel Amp
Hello Ppl.
Nice 2 meet You People. After Seeing these post i got to know about that 3ch IC. LM4780. I have Ordered the samples. coz i cannot find it in india. I am building my Second amp which is going to be a multichannel Amp. using those LM chips. Hope it would Work. I would like to have the PCB Which is Single Sided. I Did Download the PDF posted by BrainGT. but they are double sided. which i never tried to build one. So i u guys have a single sided PCB design Please post it.
Old 6th March 2005, 03:30 PM   #2
For this chip you can't correct make one sided PCB, pin configuration is too complicated and pin spacing is too small.
Old 6th March 2005, 04:42 PM   #3
Opps I dint Think of that. Neways I ll check how to make a double Sided PCB.
Old 8th March 2005, 01:32 PM   #4
It is possible. I have done it. The only drawback is that you can't always place your external inputs/outputs (speaker, power, input signal) at the edge of the PCB. Edge connections looks better, but placing the connections closer to the pins have other advantages, as less noise, resistance and coupling.
You also have to use 3 links/jumpers on the power to the LM4780. That is the only way to get all the signals and power to the IC without using a double side PCB.
I have also slightly increased the spacing between the two rows of pins. This can easily be done with the real IC. It just leaves a bit more space between the rows to route the tracks.
Hope this helps.
Paul
Multichannel DAC dunderchief Digital Source 46 5th November 2010 12:51 PM
USB DACs and multichannel with x-over - is it possible Raj1 Digital Line Level 1 24th October 2008 09:04 PM
14+ multichannel 3886 hum kramer71 Chip Amps 6 6th November 2006 02:43 PM
Multichannel T-Amp starn02 Class D 9 7th May 2006 03:22 PM
Multichannel DAC cniemira Digital Source 0 8th December 2002 04:24 PM
Page generated in 0.10063 seconds (60.23% PHP - 39.77% MySQL) with 10 queries
