| Chip Amps Amplifiers based on integrated circuits |
I have a noise problem on my parelleled 4780 amp. I have a lot of noise coming out the outputs. I hooked up the outputs to my scope and it looks like a half sine wave ~ 60hz, then 0 v then another half sine wave in the other direction. There is a gap of about 2 periods between these half sine waves. Does anyone know what is causing this?
#2 |
Electrons are yellow and more is better!
Have you checked youir supply voltage? Is it "DC" or something else".
What happens if you shorten your input? Have the two channels the same behavior?
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Yah, both channels have the same behaviour (both use the same tranny and rectifier), the noise doesn't change when I short the inputs?
#4 |
Thanks for the help. I checked out the 2 supply voltages on the scope and they seem pretty bad. (looks like lines going up and down like ^^^^^^. )
I'm currently using a 400VA toroidal transformer with dual secondary 21V outs. The 2 coils are attached together to form the ground, while the other 2 wires are rectified using 4 MUR860 diodes. Would it be better to leave the 2 coils seperated and rectify them individually using 8 diodes? I have 17600uF total between 2 parelleled LM4780s. Is this enough? |
| What components has to be present on the balanced inputs/outputs of an audio ADC/DAC? | skpb | Analog Line Level | 3 | 12th October 2006 07:30 PM |
| Changing inputs and outputs on DH-200 | jakelm3075 | Solid State | 4 | 30th March 2006 10:28 PM |
| designing inputs + outputs of electronic crossover | stinkpot | Parts | 12 | 14th May 2005 05:07 PM |
| buzz noise on outputs with no input attached | akunec | Chip Amps | 9 | 28th February 2005 11:18 AM |
| Why are XLR outputs male, and inputs female? | Bricolo | Parts | 5 | 30th August 2004 01:43 AM |
| Page generated in 0.13777 seconds (39.37% PHP - 60.63% MySQL) with 10 queries |
