Old 6th March 2005, 06:45 AM   #1
Send a message via AIM to FREQUENCY Send a message via MSN to FREQUENCY Send a message via Yahoo to FREQUENCY
Default Adding Vol Port to this LM3886 Circuit!
Hi all,
I would like to know how to add a vol port to this circuit!
I was think adding a 100k vol port on. Is that ok!
1) what value of the vol port is suitable for this circuit!
and how should I connect them up?
Frequency
Old 6th March 2005, 07:17 AM   #2
Tube_Dude's Avatar
Default Re: Adding Vol Port to this LM3886 Circuit!
Originally posted by FREQUENCY
Hi all,
Is better to use a 10K or 20K volume pot , unless you have a valve output source (high impedance output) .
The middle terminal of the pot , to the input 4,7 uF cap , one of the other terminal to the input ground and the other become the "new" input of the amplifier.
Cheers
Jorge
Old 6th March 2005, 08:27 AM   #3
sivan_and's Avatar
Send a message via Yahoo to sivan_and
The .1mfd capacitor in the signal path to ground will roll off much treble and the value should be reduced to less than 1Kpf.
SivanandBalan
Old 6th March 2005, 09:49 AM   #4
hey, sivan_and
You mean the cap 0.1uf after 4.7uf cap should be less than 1Kpf.
(the 0.1uf cap before 1k resistor) or both the 0.1uf cap along the signal.
Sivan_and quote:
(The .1mfd capacitor in the signal path to ground will roll off much treble and the value should be reduced to less than 1Kpf.)
One more question: the port should be LINEAR type RIGHT!.
Thank All!
Frequency
Old 6th March 2005, 01:17 PM   #5
sivan_and's Avatar
(the 0.1uf cap before 1k resistor) not both .........
Volume pot should be Log...
SivanandBalan
Old 7th March 2005, 02:38 AM   #6
Hi all,
Thank you for all the information!
cheers,
Frequency
Old 7th March 2005, 02:38 AM   #7
Hi All,
If there is any inprovement on this circuit just chip!
Thank you!
Frequency
Old 7th March 2005, 03:13 AM   #8
sivan_and's Avatar
Mute pin not biased....Study data sheet.......
SivanandBalan
Old 7th March 2005, 06:35 AM   #9
hi siva_and,
I had not gone into the data sheet!
biased the mute pin will get the mute funtion???
what can the mute pin help by biasing them?
cheers,
Frequency
Old 7th March 2005, 01:00 PM   #10
sivan_and's Avatar
Lots of posts in this forum...
or here : http://www.national.com/ds.cgi/LM/LM3886.pdf
SivanandBalan
Adding Subwoofer output to Aikido preamp circuit dr._sleep Tubes / Valves 5 13th November 2007 04:18 PM
Modding a XR45: adding USB port. antorsae Digital Source 4 1st February 2006 04:21 PM
How to add Vol port to this circuit! FREQUENCY Chip Amps 1 6th March 2005 07:38 PM
Adding a Port to my enclosure Maples Multi-Way 6 26th July 2004 06:29 AM
Adding a port Howard Multi-Way 35 15th August 2003 09:06 PM
Page generated in 0.14604 seconds (61.00% PHP - 39.00% MySQL) with 11 queries
