Old 5th March 2005, 08:08 PM   #1
leadbelly's Avatar
Default Balanced -> oscillation?
I just finished building my LM3875 GC. It is built similarly to the following schematic, except using BrianGT boards:
http://www.diyaudio.com/forums/showt...907#post263907
It works just fine (GREAT!) with an SE source (grounding the -), heatsinks never feeling hot. Yet if I just turn it on with input disconnected completely, it will just heat up on it own until I have to shut it down. It is not a short, this is all using a smallish fuse which never blows. Is this just runaway oscillation? I did not think that open loop gain would be such a problem with just 100K/10K resistors. No, I cannot test it with a balanced input because my preamp isn't finished.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 5th March 2005, 08:43 PM   #2
pinkmouse's Avatar
This is very common with GCs, I would guess that approx. 1/3 of the ones I have built oscillate with no input.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 5th March 2005, 08:48 PM   #3
leadbelly's Avatar
Thanks pinkmouse!
I see upon further searching that the design I chose to build has been heartily slammed. I will look around some more and plug in the desoldering iron
Old 5th March 2005, 11:53 PM   #4
homer09 is offline homer09  Canada
homer09's Avatar
If i want to implement a mute setting on my source select for my gainclone, what should i connect to it to avoid oscillation? i was planning on just leaving it open...
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 6th March 2005, 12:24 AM   #5
Banned
Default Re: Balanced -> oscillation?
You need a resistor from each input to ground.
100k will do.
Old 6th March 2005, 12:36 AM   #6
leadbelly's Avatar
Default Re: Re: Balanced -> oscillation?
100k will do.
Not so sure of that anymore. Mad_K wound up where he started:
http://www.diyaudio.com/forums/showt...017#post262017
Old 6th March 2005, 12:57 AM   #7
Banned
Default Re: Re: Re: Balanced -> oscillation?
The inputs are not terminated.
You will your speakers if you forget to connect a source.
Old 6th March 2005, 06:16 AM   #8
pinkmouse's Avatar
Just ground the input, and you should be fine.
Al
Old 6th March 2005, 07:35 AM   #9
well, that circuit listed on the site does look like it will have issues with ossilations.
not sure what effect adding a 100k resistor from inverting to ground would have on the balencing or if it even matters at this point.
on a side note thank you. i think i found out what may have happened to my last 4780 amp!
if only it could be used for good, not evil...
Oscillation raveenvijendren Solid State 15 18th December 2005 10:16 AM
GC oscillation ? Dennis Hui Chip Amps 20 28th September 2004 10:26 PM
Balanced Zen v5 + balanced Zen line stage Adrie Pass Labs 0 30th May 2004 05:27 PM
Balanced DC servo for balanced stage ? CheffDeGaar Solid State 8 9th July 2003 02:39 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Page generated in 0.13265 seconds (68.65% PHP - 31.35% MySQL) with 10 queries
