Old 5th March 2005, 04:05 PM   #1
homer09 is offline homer09  Canada
homer09's Avatar
Question Panel thickness and shielding
Im about to dive into my first chasis construction for my first gainclone.
It will be an aluminium case. Now my question is: how important is the thickness of the aluminium for shielding? Like i've seen some cases that have half inch panel thickness and others made of wood with aluminium paper shielding.
Basically i "found" an old street sign wich is a nice strong piece of 1/16" aluminium, and would be much easier to work than that thick aluminium.
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 5th March 2005, 05:14 PM   #2
Mr Evil is offline Mr Evil  United Kingdom
So that's about 1.5mm. It all comes down to the electrical resistance of the panels: Lower resistance = better shielding. Since aluminium is a good conductor, 1.5mm will provide excellent shielding.
You should bear in mind that the oxide that forms on aluminium is an excellent electrical insulator, which can make it hard to join panels together to make the shielding continuous. Ideally you should use some sort of joint that pierces the surface of the metal to ensure good electrical contact.
https://mrevil.asvachin.eu/
Old 5th March 2005, 05:34 PM   #3
Steve Eddy's Avatar
Default Re: Panel thickness and shielding
Not very.
It's almost worthless in terms of shielding from magnetic fields and shielding from electric fields is primarily via reflection loss rather than absorption loss and is more of a surface phenomenon.
More important than thickness in terms of shielding will be the holes and seams of the chassis.
se
Old 5th March 2005, 06:05 PM   #4
homer09's Avatar
Default Re: Re: Panel thickness and shielding
se
How does one make good seams? What are bad things to avoid?
Old 5th March 2005, 07:09 PM   #5
Steve Eddy's Avatar
Default Re: Re: Re: Panel thickness and shielding
Basically you just want to keep a good close fit without big gaps and other discontinuities.
se
Old 5th March 2005, 07:46 PM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It's also much easier to make a nice looking case out of a thick aluminum than the thin one. The cost of aluminum is negligable comparing to amount of work one puts when building chassis by hand. Shielding shouldn't be an issue here.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 5th March 2005, 08:23 PM   #7
Thick or thin ? It is not about shielding, but only about design ( about proportion of case ). If you need good shielding, make it from permaloy sendwich .
Old 5th March 2005, 08:44 PM   #8
Steve Eddy's Avatar
Yup. Just remember to hold the mayo.
se
Old 5th March 2005, 09:19 PM   #9
I'm not drilled in english - what is mayo ?
Old 5th March 2005, 09:29 PM   #10
BTW, the best shielding is " black hole ".
MDF thickness castropine Multi-Way 31 25th June 2009 07:37 AM
MDF Thickness harrisni Multi-Way 40 10th September 2006 08:32 PM
Panel thickness, flexing and resonance. Circlotron Multi-Way 7 14th August 2004 12:17 PM
Spkr Box Panel Thickness richie00boy Multi-Way 11 8th July 2004 08:34 AM
thickness of terminals yugaaa Solid State 3 26th January 2002 08:33 PM
Page generated in 0.13818 seconds (55.28% PHP - 44.72% MySQL) with 10 queries
