Question about Lm4780 kit
Old 5th March 2005, 08:57 AM   #1
G.L. Tirebiter is offline G.L. Tirebiter  Canada
Default Question about Lm4780 kit
Pardon my ignorance, but I'm very new at all of this. I want to build a chip amp(s) to use in a bi-amp setup. I'm a tad confused about the dual mono 4780 amp available at chipamp.com. I'm thinking that "dual mono" means two chips, each bridged. Is this correct?
Thanks in advance for the info.
Old 5th March 2005, 01:43 PM   #2
Russ White is offline Russ White  United States
Russ White's Avatar
Dual mono simply means 2 mono amps with individual power supplies.
Each amp board has both channels of the LM4780 paralleled making it a mono board.
If you share a common power supply then it is a "stereo" configuration as it is two channels sharing some common circuitry.
If you use two power supplies with two traffos then you have 2 distinct mono amplifiers, thus "dual mono".
I hope that helps clear it up.
BTW Brians LM4780 kit is the bomb. Enjoy it. I have built 6 of them.
Question about Lm4780 kitHide this!Advertise here!
Simple LM4780 Question sam9 Chip Amps 5 27th November 2005 07:29 PM
6 channel LM4780 question Wynand Chip Amps 18 24th November 2005 02:58 PM
LM4780 Question hongrn Chip Amps 4 14th October 2005 11:03 PM
LM4780 and noise (question) john_lenfr Chip Amps 12 7th July 2005 06:16 PM
Simple LM4780 question... los_ren Chip Amps 4 4th October 2004 10:18 PM
