Old 15th March 2011, 01:26 AM   #11
rubli is offline rubli  Mexico
rubli's Avatar
Send a message via MSN to rubli
Default pga2311
Hi
I am playing around this chip and made a program in a pic, and it works great, but sometimes, it makes noise (in the analog output) and gets very hot ! I have to turn everything off, and it works again (until it decides to make the same mishap)
I have no idea why it gets hot, owhat triggers it. I use .1 caps near the chips, use regulated +/- 5 volts...
any iideas ?
thanx
Old 15th March 2011, 02:07 AM   #12
Banned
Could be caused by static or other overvoltage causing latch-up.
Latchup - Wikipedia, the free encyclopedia
w
Old 15th March 2011, 02:50 AM   #13
rubli's Avatar
w
Hi Mike, thank you for such an enlightened response, I was really not aware of this phenomenon. (I am a analog guy).
I will use the diode in series option.
For this latchup matter, what is better, use a separate 5v supply for the digital supply, or share it with the analog one ? I guess for the sake of digital noise it's better separated, I have not noticed any noise sharing both supplies.
I will acquire latchupfobia !! I have burned several chips...
thanks again for your great response
regards
Alex
Old 15th March 2011, 09:42 AM   #14
SDF is offline SDF
Default pga2311 latch-up problems
I already have this problem with this chip and like wakibaki writed, it's a latch-up problem!
The datasheet doesn't talk about this problem but the cs3310's one, an equivalent design, is more explicite!
Integrated AMP with PGA 2311 preamp kpero Chip Amps 5 26th April 2009 07:05 PM
my zen test mccreamark Pass Labs 1 17th July 2008 02:11 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
CDM4 troubleshooting - green LED laser test circuit Mikelo Digital Source 6 13th May 2005 06:51 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Page generated in 0.10055 seconds (57.05% PHP - 42.95% MySQL) with 11 queries
