| Chip Amps Amplifiers based on integrated circuits |
I got the amp finally finished over the weekend and have been enjoying it ever since. This thing sounds great. I ordered 2 kits to run 2 chips per channel in parallel. I had some trouble with one of the chips having a unusually high DC offset causing one channel's chips to get real hot, but Brian hooked me up with a new one and it solved the problem.
The first thing I noticed when I turned it on was a lot more bass. Previously I was using a pioneer 1014 which did a good job, but this beats it hands down. ![]() ![]() ![]() It sure was a pain getting everything in place inside. The wire I used was very stiff. Things always seem bigger on paper, I could have used some more real estate inside to clean it up. Thanks for everyones help. I would probably have given up with out some of your tips. |
#2 |
classy case
maybe if your wire isnt too stiff, you can twist positive and negative leads to tidy things up, also improves sonics
#3 |
Very nice! Is that case your own design? I'd love to see schematics for it.
#4 | |
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa |
#5 |
Yup, Homer's right. I had a general idea of what I wanted to do with the extruded 80/20 aluminum for the corners and the wood. I ended up getting the heat sinks from a guy locally who has an aluminum extrusion plant.
The aluminum can be tapped with 1/4 - 20 thread and I used some acorn nuts to match the top of my flexy rack that I made a while ago. The overall dimensions are 12.75 D x 15.5 W x 4.75 H. |
| LED for BrianGT 3875 Kit | dsavitsk | Chip Amps | 4 | 27th February 2005 05:35 PM |
| BrianGT 3875 parts changes | dsavitsk | Chip Amps | 3 | 25th February 2005 01:34 PM |
| LM 3875 finished... | dhole | Chip Amps | 0 | 24th February 2005 07:32 PM |
| BrianGT 3875 kit troubleshooting | ejn327 | Chip Amps | 18 | 18th February 2005 02:46 AM |
| Noob ? BrianGT Lm 3875 with 10k pot? | bender460 | Chip Amps | 13 | 12th November 2004 06:14 PM |
| Page generated in 0.12782 seconds (52.60% PHP - 47.40% MySQL) with 10 queries |
