I don't think it's used in any amp...
I came up with the idea when everybody told me that it's a big "no-no" to use big caps with the gainclone...
I like big caps so something had to be done
I actually know very little about electronics, but I have worked a lot with hydraulics and this is more or less like a accumulator and the diodes are like the check valves (with a small pressure drop, opening pressure, to balance out the spring force in the check valve...)
/Stefan
/Stefan
As you may have noticed, we a fashion here. For a while 1500 uF was just about. Now we have a snubberized PS with 10000 uF. It's ,like the newpapers Aftonbladet and Expressen, which one is the best?OA51 said:I came up with the idea when everybody told me that it's a big "no-no" to use big caps with the gainclone...
The most important thing is to be pleased yourself.
