Old 28th February 2005, 10:20 PM   #1
Septimus's Avatar
Send a message via AIM to Septimus
Default Morbid curiosity, peltier cooling?
What would happen if you used a peltier junction on a chipamp. Could you up rail voltages and increase power? I'm sure this wouldn't work, but I was just curious to see what people had to say on the topic.
Old 28th February 2005, 10:22 PM   #2
Septimus's Avatar
PS. I mean use the peltier not just to heatsink, but to get the chip like, SUPER cold. You'd have to have some sort of moisture management to keep things from condensing/freezing, but other than that, any thoughts?
Old 28th February 2005, 10:47 PM   #3
Mr Evil is offline Mr Evil  United Kingdom
You would have higher power output, lower noise,wider bandwidth, higher slew rate etc. It should generally improve the specs. There may also be undesirable effects, such as altered biasing internally and mechanical stress.
Why don't you try it and see? You would need a fairly hefty heatsink to deal with all the extra power from the Peltier.
https://mrevil.asvachin.eu/
Old 28th February 2005, 11:30 PM   #4
llmobll is offline llmobll  United States
Send a message via AIM to llmobll
You'd be a brave man to try this, a low watt pelt. would get good, though you would still get a fair amount of condensation. IMO.
Old 28th February 2005, 11:33 PM   #5
if it a < 80w pelt then i dont see condensation as an issue, unless you are in a low heat high humidity environment.
i have a 60w drinks cooler and unless there is no load on it for a few hours then it doesnt get wet
i used a heatsink with 20, 10 x 5 cm fins
Old 1st March 2005, 12:00 AM   #6
Note that the cooling power (Qmax) of the Peltier must be higher than the amount of heat to be removed, otherwise it will heat instead of cooling.
Old 1st March 2005, 08:16 PM   #7
thomas997's Avatar
peltiers are very inneficient and require large amounts of power. But they are fun to work with.
Try it out and post your results.
tl494 smps, inductor wire curiosity zuzu Car Audio 0 27th July 2009 03:03 AM
Curiosity: Doppler effect for speakers? keantoken Multi-Way 6 4th April 2008 02:53 AM
peltier component cooling jamie1107 Chip Amps 9 17th March 2008 04:52 AM
SEAS 27TBFC curiosity PeteMcK Multi-Way 5 19th November 2007 02:23 PM
Peltier Module for Cooling gengis Parts 6 1st July 2005 02:46 AM
Page generated in 0.10485 seconds (64.20% PHP - 35.80% MySQL) with 10 queries
