Old 28th February 2005, 04:52 AM   #1
scone is offline scone  United States
Default effects of gain selector switch in the feedback loop?
I am going to build a preamp based on PMA's opa627/buf634 layout. It's going to drive an opa549 based amp, so the pre will have to have some amount of gain (since the max gain on opa549 is around 10, and this is not enough by itself). However, I would like to have the option of using the pre to drive different amplifiers as well, so I would like to be able to switch the gain between unity and whatever I decide for the opa549 setting.
If I put a simple SPDT switch in the feedback path of the opa627 to switch between two different resistors, will it have any negative effect on the sound? My guess is no, but perhaps others have actually tried this and know for sure?
audio projects
Old 28th February 2005, 05:26 AM   #2
Don't worry, it will be the same. But if you can't clicks by switching, make one resistor fixed ( in feedback to ground - lower gain ) and second one switchable with him in parallel ( higher gain ).
Old 1st March 2005, 05:43 AM   #3
Thanks for the suggestion... I'll implement it this way. I like the idea of having a resistor in the feedback path permanently. That way if the switch ever fails for some reason, the preamp will just revert back to unity gain.
As far as clicks go, I don't think I'll ever be changing the gain while the amplifier is on. I plan on leaving the switch directly on the circuit board (completely inside the chassis) since I think the only time I will change gain is if I move the preamp from the opa549 amp to a different amplifier. That will probably not happen often, so it won't be too much trouble to open the amp up and flip the switch manually. Plus it might be dangerous to have a gain selector on the outside... it might get pressed on accident when I'm driving an amp which expects line level input.
audio projects
Old 3rd March 2005, 12:44 AM   #4
troystg is offline troystg  United States
troystg's Avatar
My JRDG Model 2 had a switch able input gain and impendence. Both switch able on the fly. It was nice to be able to do direct comparisons between the settings. Connected to my Proceed AVP the low gain and high impedance settings were best.
Upupa, as always, has the best suggestions and sound(pun intended) advice...
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 3rd March 2005, 01:26 AM   #5
Just for correctness, adding another resistor in parallel to the feedback resistor will lower gain, not increase it, because Rf will get smaller.
Old 3rd March 2005, 02:29 AM   #6
Reklats is offline Reklats  United States
Send a message via AIM to Reklats
He could do something like this:
Old 3rd March 2005, 03:47 AM   #7
Studio gear sometimes has input gain selection, usually between +4 and -10dB to allow switching between different line levels. I'm actually going to have output gain selection, which I think has the potential of harming the amplifier depending on what setting is used. (gain of 3 = +9.5dB). I figure I'll hide the switch inside the amp and avert potential danger.
audio projects
Old 3rd March 2005, 03:49 AM   #8
touche
audio projects
Old 3rd March 2005, 02:46 PM   #9
troystg's Avatar
I think he was referring to a resistor to ground such as this. Parallel the Ri resistor with a second resistor seriesed with a switch.
But yours works also it just might be audible since it is in the "direct" signal path.
Troy
Old 3rd March 2005, 02:55 PM   #10
I was talking about switching of parallel resistors ( from - input to ground ), not about serial ones ( from output to - input ).
Valve effects loop eeka chu Tubes / Valves 6 16th October 2011 01:11 PM
Guitar amp effects loop finally done. jjman Instruments and Amps 0 21st March 2009 03:27 PM
hi-loop gain amp mfc Solid State 49 10th January 2009 06:10 AM
Gain Blockwith Variable Loop Gain Bonsai Solid State 17 11th July 2008 02:40 PM
Tube effects Loop Schematics... ? psychodave Tubes / Valves 0 23rd February 2005 06:40 AM
Page generated in 0.58723 seconds (16.22% PHP - 83.78% MySQL) with 11 queries
