Old 27th February 2005, 11:21 PM   #1
akunec is offline akunec  Canada
Default Transformer Hum
I am building an 8 channel amp with 4 3875s on one side and 4 parelleled 4780s on the other. Each side has its own 500VA 21V dual secondary tranny. I got the first side to work with the 4 3875s and it sounds great. However, I noticed that on the second side, when i turn it on with only the bridge rectifier wired, i get a hum coming from the tranny. I get all the proper voltages at the end of the rectifier. The other side will only make a hum when there is a short circuit or something. Does anyone know what is wrong with it?
Old 28th February 2005, 01:31 AM   #2
Russ White's Avatar
Send a message via Yahoo to Russ White
Only time I have had a hum is when the lm4780s were not isolated on the heatsink. Make sure you use a isolator as those ICs are not isolated and will carry negative voltage and pickup all kinds of noise.
Old 28th February 2005, 01:34 AM   #3
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
They sell those chips in isolated packages... I really would recommend you guys start buying those ones.
Old 28th February 2005, 01:35 AM   #4
Russ White's Avatar
No they don't, the lm4780 is only available non-isolated. Unfortunately.
Old 28th February 2005, 01:38 AM   #5
When I don't even have the 4780s attached, I still get a hum. They only thing that is wired is the rectifier board.
Old 28th February 2005, 01:39 AM   #6
jeff mai's Avatar
Funny thing is, the poor guy doesn't even have any chips attached to his PSU yet. You guys are solving a problem he doesn't have!
Some transformers have mechanical hum. If it's really severe you might claim to the maker that it's defective. Or you may have some DC on the mains. Search on "DC trap" in this forum to see what can be done about it.
Old 28th February 2005, 01:42 AM   #7
oh. 3886 does but not 4780. sorry :P
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 09:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 06:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 11:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 09:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Page generated in 0.08263 seconds (72.95% PHP - 27.05% MySQL) with 10 queries
