Old 3rd March 2005, 04:19 AM   #11
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Originally posted by D_GR8_1
I'm a bit confused here.
Which side do I print as it is & which one do I flip horizontally?!?
Here is a top/bottom version in black and white with no silkscreen, and with the bottom layer flipped so you should be able to etch it easier.
here is the top layer
Brian
Old 3rd March 2005, 04:20 AM   #12
BrianGT's Avatar
here is the bottom layer, good luck etching the boards.
Brian
Old 3rd March 2005, 10:24 AM   #13
D_GR8_1 is offline D_GR8_1  Australia
D_GR8_1's Avatar
The PDFs are actually what you will be seing on the final product.
I have to mirror them, print them & once transferred then I get the same layout as on the PDF.
Right?!?
An expert is someone who knows more and more about less and less, until eventually he knows everything about nothing.
Old 3rd March 2005, 01:43 PM   #14
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You don't mirror any of them, the prints go like that over each side of the board (bottom is already mirrored)
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 3rd March 2005, 09:23 PM   #15
D_GR8_1's Avatar
It seems we are talking about different things here:
Peter/Brian you guys are referring to a photosensitive transfer method.
I am referring to a Press-N-Peel transfer method.
That is why we are getting confused.
On paper once you print it, and place it on the PCB the layout gets reversed. That is what I mean by mirroring the image before printing.
Just to get things clear, what I see on the PCB is what you actually see when looking at the boards from TOP & BOTTOM, right?
Old 3rd March 2005, 10:10 PM   #16
Yes.
For Press'n'Peel you have to mirror both images.
www.audiosector.com
Old 4th March 2005, 02:26 AM   #17
BrianGT's Avatar
Originally posted by Peter Daniel
Yes.
Old 4th March 2005, 04:37 AM   #18
D_GR8_1's Avatar
On these PCB layout I cant see where Rz1 & Rz2 go.
Also it seems Cz1 & CZ2 are connected to nothing?!?
LM4780 pcb layout and others BrianGT Chip Amps 263 12th January 2008 11:26 PM
LM4780 Power Ouput with Brian's Kit rgrayton Chip Amps 13 27th November 2005 06:18 PM
Brian's LM4780 for Bass Guitar Big Pete Chip Amps 19 1st November 2005 05:35 AM
Brian GT LM4780 Bridging juan_caliente Chip Amps 15 4th September 2005 10:58 AM
Two of Brian's LM4780 boards, one toroid Russ White Chip Amps 1 27th January 2005 01:04 PM
Page generated in 0.11313 seconds (60.41% PHP - 39.59% MySQL) with 11 queries
