Old 27th February 2005, 12:53 PM   #1
revell is offline revell  Belgium
Default 36 V DC offset when source connected
The problem has probably been disussed before but I couldn't find it:
when no source is connected I have 54 mV dc offset on my GT kit when I connect a source (DVD player) the offset jumps to 36 volts
anyone who knows what to do?
Old 27th February 2005, 12:57 PM   #2
Make sure signal ground is connected
Old 27th February 2005, 12:58 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
Do you have any resistor from the input down to ground?
/Per-Anders (my first name) or P-A as my friends call me
Old 27th February 2005, 01:02 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Meneer Revell,
Gij zoudt kunnen trachten de source met een condensator in the koppelen, als het dan goed is weten we dat het ofwel de source is, ofwel de ingangsschakeling van de versterker.
Jan Didden
Old 27th February 2005, 01:04 PM   #5
I'm not sure what you mean, isn't the BrianGT kit an all-in package? I connected SG to - of the rca connector and IN to the+ of the rca connector
Old 27th February 2005, 01:14 PM   #6
Ok I tried a different source (very old walkman) and the dc remains low but when nothing is playing and the source is still connected I get a very loud hum. Maybe because it is not yet in a case?
Old 27th February 2005, 01:14 PM   #7
janneman's Avatar
You may want to post the circuit. Then we can check. Not everyone here is familiar with that particular kit you mentioned.
Jan Didden
Old 27th February 2005, 01:21 PM   #8
a diagram and more can be found here: http://www.chipamp.com/lm3875.shtml
Old 27th February 2005, 01:37 PM   #9
Tube_Dude's Avatar
Hi Revell
Use a cap at the input or a cap in series between the 620 Ohm resistor and ground.
Jorge
Old 27th February 2005, 02:08 PM   #10
Probably a ground-loop problem.
Try connecting the 2 devices chassis/ground together with a wire.
I had a similar problem (70 V AC between 2 audio devices, also not pleasant to feel on my fingers!) and resolved with the chassis connection.
Bye
Rotel RCD-971: Anyone revised the PCM63 Current Output Config-Source of DC Offset??? dtm1962 Digital Source 3 25th November 2010 09:39 PM
cmoy with 1uF input cap, DC offset from source still getting through morfic Solid State 11 5th August 2009 02:41 PM
Question about DC offset from source. theAnonymous1 Solid State 2 12th November 2006 08:07 PM
Not connected yet Andy G Multi-Way 2 14th October 2006 10:20 AM
Must I have a TV connected? Timn8ter Digital Source 2 16th March 2004 07:27 PM
Page generated in 0.11502 seconds (79.67% PHP - 20.33% MySQL) with 10 queries
