Old 27th February 2005, 09:31 AM   #1
llmobll is offline llmobll  United States
Send a message via AIM to llmobll
Default Help Wiring Toriodal Primaries
http://www.partsexpress.com/pe/showd...number=122-640
OK i'm stuck what is the correct wiring for the Primaries? I'm on 110v
BLU + VIO
GRY + BRN
// so basically i'm connecting the ends to each other. Is this correct?
Also i need someone to verify these voltages on the Secondaries
Because it is 25v+25v won't i get a voltage above 50v?
Old 27th February 2005, 06:03 PM   #2
I don't know why nobody else answered your Questions:
for Primary at 120 volts you tie the dotted together.Blue and Violet
and the brown and grey together
For the secondaries your 50 volts is realy +25 to 0(zero) and 0(Zero) to -25
It might be helpful for you if you consider the dots to indicate the positive of a dry cell or battery. so on primariy you want them in parallel and on secondaries you want them essentially in series and think of the zero points to be the neutral for the chips, and on Brian's board they will become the power ground on the amp PCB
The Red and Orange become the ground.
Sheldon D
Old 28th February 2005, 07:37 AM   #3
rodolfo is offline rodolfo  Mexico
Old 28th February 2005, 09:32 AM   #4
I got it now guys thanks a lot. The "dots" it's all about the dots!!!
Thanks!
-dan
nuvotem/talema toriodal transformers jarthel Parts 5 27th June 2007 05:47 PM
Multiple primaries question Rodeodave Parts 4 31st March 2006 05:49 PM
Unwinding Toriodal Transformers DJED Parts 14 3rd January 2005 05:15 AM
help connecting primaries Raj1 Parts 12 23rd September 2003 05:59 PM
1000va Toriodal x 2 For Aleph2 macka Swap Meet 8 28th July 2003 01:59 PM
Page generated in 0.08927 seconds (73.34% PHP - 26.66% MySQL) with 11 queries
