I did a search on battery power supplies, but... - Page 2 - diyAudio
Old 25th February 2005, 08:02 PM   #11
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
So for a few hours of listen time, 4 12v 5ah batteries would be 20ah.
Looking over the data sheets at nat. semi. it looks like 48v is a little much?
Not quite - you use 2 batteries per channel (for a stereo gainclone) to give +/- 24V per channel. Each battery will still give 5 amps per hour.
Have a look at this thread for a quick start:
click here
I have used batteries in a phono stage and they do give a very smooth sound.
Old 25th February 2005, 08:14 PM   #12
colinc is offline colinc  United Kingdom
That's not right is it? 4 @ 12V x 5Ah is 48V when wired in series but it is still 5Ah capacity.
Wired in parallel it's 12V and 20Ah, but you wouldn't want to do that.
regards, Colin
Old 25th February 2005, 08:20 PM   #13
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
One properly charged cell will produce approx 13.6V DC. So the max you can do is 3 of them in series per rail. I did some brief comparisons and it seemed like higher voltage produces better sound, but running 6 batteries is not as convenient as 4.
And using AC power with 100u BG N caps (only) is still better.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th February 2005, 08:22 PM   #14
Septimus's Avatar
Send a message via AIM to Septimus
I was talking per channel. So with only 24v, we're only running these chips at like 30watts, is that right?
Old 25th February 2005, 08:25 PM   #15
This graph shows available power levels:
www.audiosector.com
Old 25th February 2005, 08:29 PM   #16
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
I have a 48V UPS. It takes 4 12V batteries in series. It would work. Though I have no interest in doing this project for myself...
Note: APC UPS' won't work, they're 24V. My good one is an online UPS from Liebert.
Old 25th February 2005, 08:37 PM   #17
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I used an amplifier with a battery powersupply once.
A Metaxas clone, with a powersupply setup that Fred Gassman in Switzerland made for the original power amplifier.
Dont know if there is still some info on Gassman's site.
Nice ones for power amps are sealed maintenance free batteries.
For my boat i have used AcDelco's, in 5 AmpHour theirs should be great too if they make 'm.
I used a charger circuit from elektor that selected the battery it charged, that way you only need one charger, with a drop charger.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 25th February 2005, 08:38 PM   #18
12V 12Ah UPS batteries are quite cheap on Ebay, you know.
Old 26th February 2005, 12:12 AM   #19
jeff mai's Avatar
Try the batteries. In a direct comparison I found them different sounding from AC but not necessarily better.
In my setup I could do hot switching between AC and battery supplies. I used a heavy duty DPDT switch (rated for 10A) that switched between rectifier bridges and batteries. The caps were 1000uf Panasonics soldered at the chip pins, so they were always in circuit. I don't think the switching would be friendly without some reservoir caps in circuit all the time. It was important to find a switch that changed contacts on both poles at exactly the same time, otherwise a pop was heard through the speakers when switching.
With batteries, the bass was more defined and the music held together better through complex passages. Unfortunately, it was a little wiry sounding in the midrange compared to AC. I went back to AC simply because I had borrowed the batteries and had to return them. In the long term I'm not certain which I would have decided was better.
Old 26th February 2005, 12:23 AM   #20
Septimus's Avatar
Ok, so I want around 5-10ah thats fine, and I'll be using SLA type, thats decided with individual chargers.
So now I need to determine the voltage I'm gonna run. I will be bi-amping these speakers, with the top end being a 4ohm Raven R1, and the bottom as yet undecided, but some form of TL, maybe an Adire Extremis. So I'm thinking 4 mono amps, two of which would be at 24V, while the other two would be at 36V? So I could run 2 12v's on the 4 ohm one, and 3 12v's on the 8ohm amp. Does this sound logical?
Peter "And using AC power with 100u BG N caps (only) is still better." In what sense, convenience or sound?
thanks for the advice!
Battery-powered supplies vic2 Chip Amps 246 16th August 2010 04:07 PM
battery power supplies cowanrg Everything Else 12 30th January 2003 08:54 AM
Regulation in battery supplies Jarno Solid State 0 19th September 2002 08:20 AM
Battery Supplies RichardJones Pass Labs 1 12th June 2002 08:53 PM
Battery Power Supplies Jason Hubbard Solid State 21 9th September 2001 05:38 AM
Copyright ©1999-2017 diyAudio
