| Chip Amps Amplifiers based on integrated circuits |
Im having problems getting my gainclone to work. As soon as I turn it on, the chip gets really hot, and i get -21V on the outputs. So I figured there was a short on my negative voltage rail. I can't find anything. There is no heatsink yet, and the back isnt touching anything so thats not the problem. My capacitors are of the right polarity. My rectifier bridge is working properly so thats not the problem.
I disconnected the wire connecting to the neg voltage rail, and now when i turn it on, i get like 3volts on the outputs, and the chip doesn't get burning hot in a second. (A side note, im not using any input capacitor because i forgot to buy them, and i heard they are optional anyways. ) When i touch the neg voltage rail to the disconnected wire, i get a little arc so there must be alot of current running through it. Does anyone have any suggestions how to fix this? |
#2 |
I had similiar problem before but not with the same chip. My circuit is inverting(part of the BPA200 circuit) and it shorted to negative rail if the input is left open. Connecting the input to a source will bring the dc offset to a few mA.
I guess a resistor from input to ground will solve this. But I used a buffer at the input because a buffer is required for the design anyway.. |
#3 |
I think that is a different problem then mine as I do have a 47kohm from input to ground.
#4 |
try something closer to 500 ohm or 1k
#5 |
Wouldn't 500 or 1kohm affect the input impedance? National recommends between 10k and 47kohm.
#6 |
Also, I noticed that there are several V+ and V- inputs on the 4780. I only have to use one of each right?
#7 |
You should connect them all. Different pins may go to different parts of the chip, and the LM4780 is really two 3886 dies in one package, so each need their own power connectors.
| Balanced outputs used as inverting & Non-inverting preamplier outputs | gni | Solid State | 4 | 19th September 2008 04:25 AM |
| Newbie parellel 3886 speaker impedence question | 2004ex | Chip Amps | 5 | 16th April 2007 08:26 PM |
| Need schematics and board files for parellel lm3886 | clipto333 | Chip Amps | 5 | 5th April 2007 05:31 PM |
| Parellel AC filtering | lopan | Everything Else | 0 | 23rd October 2004 06:55 AM |
| wiring a sub in parellel with DVC | Hat-Rack | Subwoofers | 4 | 8th March 2002 01:15 PM |
| Page generated in 0.09932 seconds (77.08% PHP - 22.92% MySQL) with 10 queries |
