Old 24th February 2005, 09:51 PM   #1
akunec is offline akunec  Canada
Default LM4780: is Cin optional?
I forgot to order Cin 1uF caps from digikey. I have other pp caps but only up to about 0.1uf. I also have some polarized electrolytic caps around 10uf. Could I use one of these caps instead?
Old 25th February 2005, 02:50 AM   #2
Mr Teal is offline Mr Teal  Canada
I'm a newb, so take what I say with a grain of salt, but lowering the value of the cap will lower your input cutoff freq. If you're not using the amp with a preamp that's DC coupled (ie, if your preamp already has a DC blocking cap at the output) you should be fine.
Old 25th February 2005, 03:13 AM   #3
It seems like you can not use it, because all it does is prevent DC from getting to your speakers. Don't try the amp the first time with good speakers in case your source has any DC output. It also helps eliminate turn on/off thumps from your source (not the amp).
You can always go to a local electronic store. It may be a lot more money, but if its only one part, I think it's worth it to put it in.
Is the 22uf C2 (feedback cap) in LM1875 optional mudihan Chip Amps 22 17th April 2009 09:33 AM
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 01:37 PM
MY LM4780 Amp ziling Chip Amps 7 6th July 2007 06:46 PM
Optional mute and reseter DJ_Looly Digital Source 0 31st December 2004 09:36 AM
Page generated in 0.06284 seconds (71.90% PHP - 28.10% MySQL) with 10 queries
