| Chip Amps Amplifiers based on integrated circuits |
i have a 200va transformer with 20v secondaries i was wanted to know about how many dc volts would this produce? the transformer is rated at 3 amps. And, would this be able to supply a single lm4780 amp?
#2 |
AC x SQR(2)
in your case 20 Vac x 1.41 = 28.2 Vdc That transformer is fine for 1 4780 chip.
Tesla boyz |
#3 |
Should produce 28 volts dc. And i would think from what i have read that would be enough for one chip amp.
#4 | |
Actual DC will be 26.7 to 27.2 depending on the forward voltage drop of the rectifiers you use. They need 1-1.5 volts to forward bias. |
#5 |
It also depends on the value of the filtering cap.
I recently build an amp with experience like this: Transformer secondary voltage:34V-0V-34V(approax) Rectification:full wave bridge DCV with 4700uF:41V(approax) DCV with 4700uF+470uF:46V(approax) |
#6 |
big help guys thanx
#7 | |
#8 | |
Looks like Sponge Bob has killed another thread. |
#9 |
Strange hah???That's what came out,more capacitance more voltage.No idea what cause this.
#10 | |
Not just strange... this is bordering funky. Is the experiment repeatable , with different values? I mean I never got a 10-12% increase by doubling my caps let alone slightly increasing them. Granted for very low levels of capacitance, you will get some gain of rails especially under load, but this is too good..... to be real. |
| Amp power supply question | theAnonymous1 | Solid State | 12 | 30th August 2008 06:06 AM |
| 813 power supply question | Richard Ellis | Tubes / Valves | 6 | 14th December 2007 04:41 AM |
| Another Power Supply Question | soundbadger | Tubes / Valves | 12 | 10th October 2007 01:29 AM |
| Power supply question | HugoR | Tubes / Valves | 9 | 9th November 2005 09:34 AM |
| Power supply Question | Adam M. | Chip Amps | 10 | 4th May 2005 03:19 AM |
| Page generated in 0.10715 seconds (80.17% PHP - 19.83% MySQL) with 10 queries |
