Old 23rd February 2005, 05:36 AM   #1
toque_101's Avatar
Default GC Transformer Considerations for 4 ohm spk
Hi Everyone,
Going to be assembling my LM3875 BrianGT kit soon and was wondering which transformer to go for. I currently have 8 ohm (~88db efficiency) speakers but will probably be moving to 4 ohm (89db efficiency) speakers eventually.
Currently I am running my lm3886 gc on 500va, 17.5 volt secondaries with no problems into my current 8 ohm speakers.
So, the transformer I was going to get is dual 18V, 300VA plitron. But, does the lm3875 require a higher supply in order to drive a lower impedance speaker? I was thinking of going to 20 or 22 volt secondaries instead? Any comments?
-steve
Old 23rd February 2005, 05:48 AM   #2
jeff mai's Avatar
Default Re: GC Transformer Considerations for 4 ohm spk
No - it's just the opposite, in fact. The LM3875 does better with lower rail voltages into 4 ohms. It has to dissipate less heat this way. The ideal situation, however, is to use your LM3886 amp on the four ohm speakers. It was designed to run at 4 ohms.
Read the National Semiconductor datasheets for these chips. It tells you all about this. Also, there is a lot of material you could find by searching this forum. This issue has come up literally dozens of times.
Old 23rd February 2005, 08:05 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
True,lower supply rail safer for lower load
Old 23rd February 2005, 02:54 PM   #4
toque_101's Avatar
Thanks for the responses guys!
X amp considerations DiMenSioN Pass Labs 26 30th May 2007 11:21 PM
Transformer Considerations MikeLewis Chip Amps 4 1st September 2005 08:31 PM
P3A considerations sobazz Solid State 52 3rd January 2004 02:19 PM
Page generated in 0.08208 seconds (73.77% PHP - 26.23% MySQL) with 10 queries
